- Springfield, Missouri
My current reloading bench has become quite crowded and this winter my dad picked up a couple of used Dillon presses from other residents in their retirement park, which he wants to set-up in my shop (darned the bad luck )
So in an attempt to save time, I thought I may try out one of these metal frame benches ($75) to replace my existing wood reloading bench.
In appearance it looks good, but given the weight rating and the weight of the box, I should have known better. It's solid side to side, but the front to back direction it wobbles quite easily. So I'l be adding some cross braces to remedy this.
I split a piece of 3/4" ply down the middle and doubled it up for the top. I'll be putting a piece of masonite over this to smooth things out with a hardwood edge.
Overall, it's usable, only took me about 20 minutes to assemble, the bracing will be an easy fix, and it should serve its purpose.
