Results 1 to 8 of 8
Thread: Basswood Bowl
    Goodland, Kansas
    4,834
    Basswood Bowl
    Well got a piece of basswood from Dick Strauss. Got around to turning it yesterday. It has a lot of spalt in it. Was kinda punky and difficult to turn. I busted the tenon off 3 times and decided to use a faceplate which meant screw holes. So I saved the sanding dust mixed with epoxy to fill them. The Hunter tool worked pretty good on it and also spent some time sanding. I think it turned out pretty good especially with the spalt. So anyway with a little patience made it work. It has 1 coat of antique oil on it. It is 10" X 4".
    Attached Thumbnails Attached Thumbnails Basswood Bowl 2.jpg   Basswood Bowl 4.jpg   Basswood Bowl 5.jpg
    Bernie W.
    Sep 2007
    613
    Bernie, very nice bowl, I can see the filled screwholes, were you able to sand off the turning marks, as I can see that this is pretty hard stuff to turn.
    Had last the same with a piece of Prunus, oh boy, not to sand.
    Keep em coming Bernie.
    Ad
    Looks great, too bad about the screw holes, but well worth the save, sure is lovely wood!
    30,019
    Sometimes you do what you've gotta do. Nice save, Bernie.
    810
    Nice wood Bernie, and nice looking bowl too!
    11,833
    I wouldn't usually think of Basswood as turning stuff, but, with that spalting you made it into a pretty object.
    Jul 2007
    DSM, IA
    5,719
    Bernie, I read an interview with David Ellsworth that stated everyone's pieces used to have screw holes...well many of mine still do.
    Well Done! Never knew basswood could look that good.
    My Website
    Goodland, Kansas
    4,834
    Thanks all. Yes this was probably the hardest piece I had to turn. A couple of places I used epoxy mixed with DNA to the consistancy of milk painted on the soft spots till it wouldn't take anymore. The LOML says it will make a nice fruit bowl. I really like the spalting and color of it. I will post another picture when I get the final finish on it.
    Bernie W.
  1. 8/4 basswood needed
    By Jerry Ingraham in forum Old Ads
    Last Post: 12-01-2010, 10:45 PM
  2. great Basswood
    Last Post: 08-18-2010, 07:22 PM
  3. Basswood?
    Last Post: 01-20-2009, 01:02 AM
  4. Birdseye Basswood ???
    By John Bartley in forum General Woodworking Q&A
    Last Post: 10-27-2008, 03:03 PM
  5. The Sad Basswood Saga
    By Travis Johnson in forum General Woodworking Q&A
    Last Post: 02-26-2008, 03:27 AM
