Results 1 to 10 of 16
Thread: Re Choice of Jointers
    12,264
    Unhappy Re Choice of Jointers
    Hi All
    I have in mind to purchase an 8"jointer. I decided it is going to be a Grizzly and have two choices but need help finalizing my decision.
    What are merits of the differences between these two machines.
    http://www.grizzly.com/products/8-x-...ile-Base/G0656
    and the
    http://www.grizzly.com/products/8-Jo...ram-Beds/G0490
    There is only $100 difference in the price one has parallelogram bed but both are 3hp motors and both have 4 cutter heads.
    Any advice will be greatly appreciated.
    I intend making a road trip from Canada to the Grizzly store in PA since up in Canada we cannot order Grizzly and the only other choices are a rip off.
    Thanks
    Rob
    11,833
    Part of Grizzly marketing genius is that they price models so close together. Sometimes the difference is only $20.00. Very tempting to step up a notch. Personally, if yer budget is OK with it, I would pop for the extra hundred.
    9,077
    The p-beds on my G0490X have already earned a place in my heart. I may not have to adjust them again for years but it took hardly any time at all.
    P.s. As long as you're making the trip, I would recommend the spiral cutter head if the budget will stand it; they're a joy to use.
    Cedar Park, TX
    320
    The benefit of the parallelogram beds is that they don't suffer from a problem of the old fashioned non-parallelogram style which use dovetail ways on which the bed mechanisms slide in order to move the beds up and down. Very little wear of these bearing surfaces allows the beds to tip a little in one direction or the other requireing that shims be added to make up for the wear. Linkage suspending the beds in the parallelogram types can be adjusted independent of each other to adjust for wear and tear.
    Jerry
    The Heart of Dixie
    4,268
    I agree with what Jerry said totally.
    If it were my money I would buy the wedge bed though. My take is how much wear will dovetail ways see? It's not like we adjust jointer's constantly like other machines. Assuming they are using decent quality cast iron, wear shouldn't be an issue. With just a normal care if should never get out of square. And even it it did, it's simple to shim. Nothing against the other one, I would just rather have the $100 in my pocket. But I am typically in the minority there.
    Custom built boats and Kits
    5,323
    I agree with Jeff. Wear isn't an issue.
    The only time I ever move the beds on my jointer is during/after knife changes. Otherwise, I generally keep it set for a 1/32" cut. I've moved it from 1/32" down to 1/16" once in a while, but not often, and I just can't see that minimal movement of the bed causing much wear on the ways.
    The Heart of Dixie
    4,268
    ..... I generally keep it set for a 1/32" cut. I've moved it from 1/32" down to 1/16" once in a while, but not often, ....
    Thats it exactly. On my 6" jointer I rare move it off 1/32". My 12" I do move it more often. Since I can flatten wide boards I will drop it down to take off a bigger bite when starting with rough sawn lumber. But even so that movement is minimal. Once every couple of months?
    12,264
    Re Feedback
    Thank you all who replied. I really appreciate the feedback. I quiet frankly could not work out what the difference was now I know. I also apologize for posting another thread here about the same jointer. I have since found another post with loads of info about these machines.
    I guess I will settle on saving the 100$. I dont believe I will wear this machine out in my lifetime and can then spend the money I save on some other "essentials".
    12,264
    Update on jointer purchase
    I thought since so many gave very valid advice on the subject I would let you all know which jointer I settled on.
    I went on a father son road trip to Washington this summer with my 14 year old son. He wanted to see the Smithsonian and I was only to ready to oblige also to get the time to be together without anyone else. On the trip down we took my little utility trailer and stopped at the Grizzly store in Muncy P.A.
    Boy I was like a kid in the candy store and in the end I purchased the Go656. See picture below. I also stocked up on a bunch ofther things while I was there given the prices of these things in the USA compared to Canada and that is with an approximately even dollar. You guys and gals in the USA are luckly. Saved on the transportation but had to pay the state taxes even though I was from out of country.
    Attached Thumbnails Attached Thumbnails g0656 jointer.jpg   Venter Trailer.jpg
    London, Ontario
    3,383
    Congratulations, Rob. It's hard to argue with prices like that. Hope you never need warranty though. That sure is a small utility trailer. Did it fit? I would have stopped on the way home, though. Now you had to drag all that weight around for the whole trip.
  1. Are these older Craftsman jointers worth my time?
    By Tom Baugues in forum Old Iron
    Last Post: 09-06-2012, 01:41 AM
  2. best saw choice
    By ken lutes in forum General Woodworking Q&A
    Last Post: 01-22-2010, 06:53 PM
  3. Jointers and Planers
    By Bruce Niceley in forum General Woodworking Q&A
    Last Post: 12-13-2008, 09:32 AM
  4. Amazon and the Delta DJ20 8" and DJ30 12" jointers
    By Mike Heidrick in forum Hot Deals
    Last Post: 02-27-2007, 03:06 PM
  5. Speaking of Jointers....
    By Jeff Horton in forum Old Iron
    Last Post: 12-14-2006, 10:48 AM
