Results 1 to 4 of 4
Thread: Dovetail Mortice & Tennon
    WNY, Buffalo Area
    873
    Without a doubt I am a power tool guy, but I do appreciate & respect the skill involved in working wood with traditional hand tools. So once a week I record an episode of "The Woodwright's Shop" with Roy Underhill. I like to see different and more traditional ways of how things were done. I suppose knowing about where the craft came from and evolved helps me in its "modern-power tool based" practice.
    Anyways..... Last week Roy did an entire episode on differnet types of dovetails. He showed a mortice and tennon dovetail joint. This is something that was entirely new to me.
    He made a tennon with 2 kerf cuts in the end of the tennon. He then cut a mortice that was in the shape of a dovetail (narrow at the opening(top), and wider at the bottom). He then tapped a wedge into each kerf in the tennon, but not far enough to make the tennon spread wider. He then tapped the piece of wood with the wedges sticking out of the tennon into the mortice. When the tennon bottomed out in the mortice, the wedges spread the kerfs wide enough that the tennon was then locked into the mortice by the dovetail shape and friction.
    I have seen a version of this where the mortice was a through-mortice where the wedges spread the tennon pinning it in place, but not one done this way.
    I did a quick sketch of what this looked like, incase my description was confusing.
    Has anyone else seen or used this type of joint before?
    www.tinyurl.com/thewoodshoppe
    Cedar Park, TX
    320
    I've seen one done on a butcher block table to attach the legs without a skirt. Very effective until you need to replace a broken leg or some such. Just a variation on the wedged mortise and tenon, which like you said are mostly seen as through M & Ts. But since you wouldn't be able to identify a blind one without disassembling the joint, they could be used more often than you know.
    Jerry
    5,320
    As john said, it's a 'fox wedged tenon.' One downside to them, though, is that you only get one chance to get it right. Once assembled, and the wedges seated, it ain't coming apart - ever.
    It can also be done with a through mortise, with the wedges driven in after the basic assembly. This is fairly common in chair making, where the legs protrude up through the seat, and are then wedged.
    Florence, AL
    9
    Somewhere recently I saw an advertisement for making those joints. Can't remember which magazine it was in though.
    Seldom Wrong, but never in doubt!!
    My Blog: The Saw Dust Pile
  1. Help, can't get mu Mortice machine to cut
    By Don Baer in forum General Woodworking Q&A
    Last Post: 11-17-2009, 11:55 AM
  2. FS: Sorby Boxwood Handled Mortice Chisels
    By Jim Galvin in forum Old Ads
    Last Post: 06-26-2009, 12:24 PM
  3. Tennon Question again
    Last Post: 02-09-2009, 02:18 AM
  4. Day off and Tennon Problems
    Last Post: 01-06-2009, 06:52 PM
  5. Fixing a mitered mortice and tenon joint
    By Alex Reid in forum General Woodworking Q&A
    Last Post: 06-06-2007, 12:34 AM
