Results 1 to 5 of 5
Thread: Stanley #4 with small crack at mouth- ok for a user plane?
    Atlanta, GA
    194
    I can potentially get this plane free, but it does have a small crack on one side of the mouth. Will it still work fine as a user plane?
    so long as the crack doesn`t scratch the wood or permit the blade to come out of adjustment.
    5,321
    Quote Originally Posted by Charlie Schultz View Post
    Is the crack up the cheek (side) of the plane, or across the sole?
    Either way, the plane will still work just fine, so long as it's not scratching the wood.
    Often, cracks radiating up the cheek, from the corner of the mouth, will allow enough stress for the opposite cheek to crack, too. When that happens, the whole front of the plane falls off, making your #4 into an 'instant bullnose' plane.
    #4's are common enough that it's really not worth repairing, so I'd just use the plane until it breaks. That might happen in two strokes, or in 20 years. No way to tell.
    Get as much use out of it as you can, then put the tote, frog, iron, chipbreaker, and lever cap up for sale on Ebay. You may find that the parts are worth more on Ebay than a whole, intact, #4 would bring.
    Atlanta, GA
    194
    Thanks for the info guys. The crack is on the sole.
    Central NY State
    3,374
    What the gents above said. But I'm going to turn Jim's suggestion around. Use it as you can, and if it quits then keep all the parts and buy a No. 4 body on ebay. You can find them for $5 or less sometimes.
    A crack in the mouth MAY make a plane unusable. Don't struggle with it if it isn't working.
    A picture of the plane might be interesting to post...
  1. Stanley #45 plane
    By Jeff Brockett in forum Old Ads
    Last Post: 04-04-2009, 11:04 PM
  2. Replies: 7
    Last Post: 07-15-2008, 10:12 PM
  3. Replies: 0
    Last Post: 07-02-2008, 08:24 PM
  4. Stanley No.11 Plane
    By Sean Wright in forum Neander Woodworking Q&A
    Last Post: 06-02-2008, 12:48 PM
  5. Is this a Stanley 12 3/4 plane?
    By randy street in forum Neander Woodworking Q&A
    Last Post: 11-28-2006, 02:53 AM
