Results 1 to 8 of 8
Thread: Some Mini Bowls....
    Some Mini Bowls....
    If you remember, I roughed out a bunch of NE bowls and such from some wood I got from the local Shinto Shrine, well, I took a stab at finishing some today, to take to Canada with me..........
ID:	22137 Click image for larger version.
ID:	22138 Click image for larger version.
    Not the best pics, sorry, but I'm pressed for time.
    Turned out OK, I guess, just a basic wax finish, buffed.
    Sure is fussy work getting into the bottom of these smaller bowls, even with the 3/8" bowl gouge
    The first pic has a Zippo lighter in it to give you some scale.
    Jul 2007
    DSM, IA
    5,719
    Stu are those the same kind of wood? The one on the right sure has some nice figure in it. Are you going to need an extra suitcase for all the gifts? I'm sure everyone will love them!
    My Website
    564
    Stu, I like your little bowls and I like turning little bowls. For that reason I have two 1/4" bowl gouges. One has a standard swept back Irish grind/side grind. The second has a much shorter standard grind which I have shortened even more by grinding a second bevel on so you can turn inside small bowls.
    Try it, you'll like it.
    I may be getting a little older physically but mentally I'm still tarp as a shack.
    30,008
    Those are cool, Stu. I'm sure they'll be appreciated.
    Mike...I'm shocked. You turn bowls?
    Los Angeles, CA
    2,668
    Stu, nice set of bowls. Second bowl has interesting figure on it.
    564
    Yessir, I do. I just don't post a lot of pictures. Most of my bowls are minis. I also turn lots of orts bowls. I know it is hard to believe.....
    Thanks guys!
    Mike, I can sure see where the 1/4" gouges would come in handy, and the double bevel, well, I've been advocating that since Eli Avisera showed that to our group here nearly two years ago, it really does work!
    Goodland, Kansas
    4,834
    Those are cool Stu. I really like both of them.
    Bernie W.
  1. Replies: 14
    Last Post: 01-14-2014, 03:57 PM
  2. mini get away
    By Stephen Bellinger in forum Off Topic Discussion
    Last Post: 07-18-2010, 08:50 PM
  3. Mini-max C22
    By Darren Wright in forum Hot Deals
    Last Post: 01-31-2009, 04:41 PM
  4. which mini to buy
    By Joan Keeler in forum General Woodturning Q&A
    Last Post: 08-14-2007, 01:41 AM
  5. WoodRat Mini-Mini Review
    By Frank Pellow in forum New Tools
    Last Post: 11-23-2006, 06:41 PM
