Results 1 to 5 of 5
Thread: I'm green and yellow with envy.
    Westphalia, Michigan
    955
    I spent the evening turning some walnut bowls. I got this chunk from a guy whom I cut up large log butts for. He heats his moulding factory with the butts from large logs. Anyway I was turning these butts into 'cookies' so he could fit them in his furnace and spotted this walnut piece that was where 2 limbs grew together. the area between the limbs was all crazy grained. I scribed out a 13" x 11" deep blank that included half of each limb and the cool grain in between. I got 2 small blanks from the off-cuts. (6" dia.)They turned easy and went into the alcohol soak. I then chucked up the big piece and with great trepidation fired up the lathe. I have a grizzly 1067Z and it was almost all that lathe can handle. I first had to make a new extension for my tool rest because the cheap casted rest that came with the lathe broke off some time ago. I did manage to true up the bowl and got it ready to chuck up.
    This big bowl is being turned end grain and every time I would start a pass the variable speed lever would advance by itself. I kept reaching over to attempt to slow tha bugger down before launch. I finaly tied the lever down , but not before the chuck came loose from the adaptor nut. I find that it will be a long slow process to get the thing hollowed out. All the while I was having visions of the mustard machine I once ran......someday......someday
    30,008
    Wow, 13" x 11" is big on pretty much any lathe. Sounds like a piece worth fighting for, though.
    (And the Mustard machine is worth the wait.)
    May 2008
    Benson, Arizona
    34
    Paul sounds like it was fun project. It always amazes me whats inside a log. Good Luck..Bruce
    Always like learning something new!
    11,828
    Minimum speed on your lathe is 600 rpm, a real whizzer for a large hunk. If you just put some WD-40 on the stop pin on the speed control lever, it might solved the problem. They do stick. Do be cautious with a big, out of balance, hunk going that fast. Wear face protection.
    955
    Body armour and a face shield. Just kidding on the body armour. I have seen firsthand the result of not wearing a face shield. A co-worker of mine was grinding overhead in a die with a wheel too big for the rpm of the grinder. It blew up and smashed his face; broken nose, cheekbone, eyesocket and bad lacerations. I don't need another object lesson. I'll try the wd-40 on the lever.
    This is my first time turning end grain. I know a local master turner who exclusively (most of the time) turns end grain and I'm going to go pay him a visit. He has developed specialized tools for doing his thing. He is a retired toolmaker. I've also been eyeballing that Ci1 tool, and trying to decide if I will make something similar or buy one. I also have a bunch of tool bits and bars, etc. that I picked up a few years ago with the same idea in mind. I used to use a lot of insert toolng at work.
    One such tool I want to make utilizes a 3' bar, 1-1/4 wide x 1/2 thick. It is tapered at the nose and has a 't' slot milled in it to take 1/8" thick x 1/2 wide cobalt enhanced tool steel bits. Basicly a scraper on steroids. The heavy mass of the handle goes a long way toward dampening the shock of turning. I just have to get my carcass over to a friend who has a mill to cut the 't' slot.
  1. What's all this yellow dust?
    By Roy Bauman in forum Off Topic Discussion
    Last Post: 05-30-2016, 02:12 AM
  2. Green and Green square plugs
    By Charles Hans in forum General Woodworking Q&A
    Last Post: 02-01-2013, 12:40 AM
  3. Yellow Heart
    By Jiggs Elphison in forum General Woodworking Q&A
    Last Post: 10-03-2010, 02:46 AM
  4. Yellow birch
    By Al killian in forum Off Topic Discussion
    Last Post: 05-01-2009, 08:38 PM
