Results 1 to 10 of 12
Thread: Stablizing Pen Blanks
    Sep 2007
    Murfreesboro. Tn
    8
    I have been reading Lathe Land for about a year and you all have solved a lot of problems for me. Now It's time to ask one. When you stablize a pen blank using CA glue, why does it help to use a vacuum pump instead of just soaking it? Also how long do you leave the vacuum on when putting the glue on the wood? How thick a pice of wood can you stablize?
    One last question: Has anyone heard of taking acrylic plastic and desolving it in acetone and stablizing pen blanks with that solution.
    lutefisk capitol, USA
    485
    Yes you can. There is a tutorial on www.thepenshop.net on doing the plexiglass/acetone stabilization including how to build a pressure pot.
    30,015
    Quote Originally Posted by Pat Rooney View Post
    ...why does it help to use a vacuum pump instead of just soaking it? ...
    As I understand it, the vacuum helps pull the air out of the voids in the blank, and the air gets replaced by the stabilizing material. It just helps ensure the stabilizer penetrates deep into the wood. I'll leave the other questions to others who know more than I do. Dale's link to the pen making forum should get you pointed in the right direction.
    Westphalia, Michigan
    955
    You want to make sure to use non-siliconized plexiglass. That is the cheaper grade anyway. I pick up scraps at a local big-box store. The plain plex will disolve in ascetone but the siliconized stuff will turn a goopy white mess. I have some made but have'nt used it yet. It is about the consistancy of syrup.
    The vacuum is used to pull the mix into the wood. Most folks I know doing this also pressurize the pot after it has been under vacuum for a while.
    Most folks are also using a harbor freight pressure pot. I don't know any who use CA glue AND vacuum. I use CA glue right on the lathe when I run into a problem spot in a pen. Punky wood or cracks are the normal situation that calls for some CA glue. Some people also use minwax wood hardener to stabalize wood. Another method utlizes Alumilite resin with Vacuum. Alumilite is a 2 part poly resin (I think it's poly). I cast pen blanks with another brand of poly resin that takes a few drops of activator per ounce. It is generaly too viscuss to get descent penetration into wood. The white alumilite is water consistancy.
    11,831
    Dale and Paul beat me to it with the best responses. Almost everyone that stabilizes has his own secret receipie. Let us know how it works. I'm looking for a used paint pot and will be plunging into this business shortly.
    485
    Frank, I have a lead on some used pots. I will let you know what I find. Can't cost too much to ship aluminum.
    11,831
    Quote Originally Posted by Dale Johnson View Post
    Great. Give me an e-holler.
    Sep 2007
    Murfreesboro. Tn
    8
    Thanks everyone for the help. This was my first post and a great experience.
    30,015
    Don't ever hesitate to ask questions here, Pat. We'll give you plenty of answers, even if we don't know 'em.
    Seriously, I'd guess for every one person who posts a question, there are at least ten people who were wondering the same thing, but felt uncomfortable about asking the question. And over time, a hundred people will learn from the single question, and the thread gets found via searches.
    Thanks for asking the question.
    North West Indiana
    6,098
    Yep and welcome aboard Pat. Feel free to join in these here discussions. If you need help interpreting Larry's posts, well you are on your own there!
  1. A few Blanks...........
    Last Post: 06-22-2015, 04:08 PM
  2. pen blanks
    By John Daugherty in forum Classified Ads
    Last Post: 01-20-2013, 11:29 PM
  3. Pen blanks
    By Bart Leetch in forum General Woodturning Q&A
    Last Post: 10-22-2008, 11:52 PM
  4. DIY Vacuum Chamber For Stablizing Wood
    Last Post: 05-22-2008, 07:27 PM
