Results 1 to 9 of 9
Thread: First Turquoise
    Mason Michigan
    455
    First Turquoise
    I thought I would try the turquoise that I ordered a while back. I first purchased a how to DVD from Larry Fox at http://home.earthlink.net/~larryfox/.
    I used the C1 to cut the stone and it worked very well.
    Any comments or critiques are welcome.
    "Small Change got rained on with his own 38"
    Tom Waits
    Red Deer, Alberta, Canada
    618
    Absolutely gorgeous, Pete.
    I'd be interested in how you did that but probably won't spring for the DVD. Is there any information anywhere else?
    Why has common sense
    become so uncommon?
    My Woodwork Site
    Goodland, Kansas
    4,834
    As I said Pete that is a beauty. I like the rim treatment.
    Bernie W.
    I like it Pete. That's very cool. The band of turquoise is a bit wider than you often see...I like it.
    13,454
    Pete, that is very cool. Love the use of different mediums in a project.
    11,833
    Very pretty. I like your use of the material and treatment of the bowl. Isn't that stuff pretty expensive?
    Mason Michigan
    455
    Thanks for the comments!
    Frank, I bought the stone at http://www.colbaugh.net/home.html for $15 a pound. If you call them you have to ask for floor scraps.
    Gord, the process is pretty simple. You crush the stone and screen them into three sizes: dust, tiny stones and stones about 3/16. Then mix about 2 square inches of 5 minute epoxy and cover the epoxy with the dust. Then the big stones and finally the middle stones. Mix and apply with a chisel and let dry. Larry sands with a belt sander and then circles on a disc. If there are any air bubbles he fills with dust and thin CA and sands to 400.
    I cut with the C1 instead of belt sander
    Tom Waits
    11,833
    Thanks for the tip.
    Jun 2007
    Kirkintilloch, Scotland.
    230
    Pete really like your bowl the turquoise band adds an unusual and nice touch to it
  1. Turquoise Dye
    By Dietrich Trenner in forum Finishing School
    Last Post: 03-01-2012, 02:18 AM
  2. Turquoise Inlaying
    By Dave Dumas in forum General Woodworking Q&A
    Last Post: 01-03-2011, 10:07 PM
  3. Curly maple w/ crushed turquoise inlay rim
    By Nathan Hawkes in forum Lathe Project Showcase
    Last Post: 03-21-2009, 01:40 AM
  4. Box Elder burl bowl with turquoise
    By Curt Fuller in forum Lathe Project Showcase
    Last Post: 07-26-2007, 08:43 PM
