Results 1 to 5 of 5
Thread: chatter in oak
    Apr 2008
    Butte Montana which is 1/2 way between Purgatory and Heaven
    170
    chatter in oak
    I'm trying to rout a 3/4 inch slot in oak and I'm getting severe chatter - I've tried both a straight bit and a spiral bit -could the cause be speed?
    The Heart of Dixie
    4,268
    Not a big fan of routers but the principle is the same as in metal working. It is a balancing act between RPM, feed rate and depth of cut. My guess is your taking to much material off at once. But trying adjusting those and you will find the sweet spot.
    Custom built boats and Kits
    I route oak quite a bit. With a 3/4" bit I take 1/8" bites at full speed with a Mil 5616 and it is real smooth. Does the router feel in control and it's more of a sound thing or is the router jumping in your hands? You didn't mention whether it was red or white. Red oak is pretty fiberous stuff so grain direction gets more critical. My .02.
    Here's something on grain reading: http://www.taunton.com/finewoodworki....aspx?id=26705
    Nov 2007
    Bedford, KY
    37
    Like Glenn says, take small amounts. Be careful you don't break the router bit with that chattering, especially if it's a 1/4" shank. If your using a straight edge, I always like to put them to the left side of the router.
    Quote Originally Posted by Norman Pyles View Post
    Norm bring up a good point. Straight edge on the right would result in a climb cut.
  1. Plane chatter
    Last Post: 05-08-2012, 03:47 AM
  2. Larry Marley Chatter tool
    By laurence moughan in forum Turning Tool Questions and Show & Tell
    Last Post: 01-29-2009, 09:51 AM
  3. Homemade Chatter Tool
    By Joe Collazo in forum Turning Tool Questions and Show & Tell
    Last Post: 03-02-2007, 08:48 AM
