Results 1 to 7 of 7
Thread: Roofing Question
    Jul 2007
    Grove City, Ohio
    57
    Roofing Question
    My shop roof is a low pitch, about 2 in 12 to 2 1/2 in 12. It currently has a rubber roof that was laid over OSB and the rubber has not stuck to the OSB well. Also, the rubber roof is ugly. The shop is attached to the back of the house. I want to install a new roof and I was thinking of laying shingles over the top of the rubber roof. Any thoughts on this?
    The Heart of Dixie
    4,268
    I don't think you can (should) put shingles on that flat of a roof. Unless you double them up. I THINK that what you need is Roll Roofing on that flat of a roof.
    Custom built boats and Kits
    13,450
    I'd agree with Jeff. Shingles aren't usually recommended unless it's at least a 4/12 or greater pitch on the roof. Even with the rubber it would be iffy.
    11,833
    Metal.
    The Heart of Dixie
    4,268
    I am not a fan of metal roofs, but I think Frank is right and it makes good sense on a low pitch.
    low roof pitch
    I wouldnt use shingles on anything under 3/12 and then only if it was protected with ice and water shield.
    But you can use an ashpalt roll roofing called "half lap" which is a rolled roofing product that has granules on the lower portion and a nail/cement down strip for the top half.
    Waterford, MI
    773
    Well I hope I'm not hijacking this thread too far, but within the next week or so I need put something on a 4'x6' totally flat roof on a dog house. I was thinking of using some leftover roll of ice dam then getting some roll roofing over that. Hopefully I can find a damaged bargain roll for the small amount I need. This is over a 3/4 MDO roof with wood "drip edge" on the ply edges. OK? Or should I be looking at metal or rubber for this too?
  1. Roofing time
    By Ned Bulken in forum Carpentry and Construction
    Last Post: 08-13-2012, 11:49 AM
  2. Question about Metal Roofing
    Last Post: 10-26-2010, 12:34 AM
  3. A little roofing question......Now a COMPLETED Job.....
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 01-21-2008, 01:35 PM
  4. Question about roofing a covered patio
    By robert dewinter in forum Carpentry and Construction
    Last Post: 10-14-2007, 05:14 AM
  5. Roofing Question
    Last Post: 08-05-2007, 09:38 AM
