Results 1 to 10 of 17
Thread: How do you cut tennons?
    The Heart of Dixie
    4,268
    I have a project with a fair amount of tenons to cut. I have a tenoning Jig for the Table Saw. I tuned it up yesterday and finally got it to cutting square shoulders.
    I know there are several ways which these can be cut. Just trying to settle one method that works for me.
    Custom built boats and Kits
    5,533
    I built a tenoning jig from an article in Popular Woodworking. They have the jig up on their site.
    Popwood Tenoning Jig
    -Ned
    5,323
    I usually use the tablesaw and tenoning jig, but if you have a lot of same-sized tenons to cut, you can cut the shoulders on the tablesaw, then move to the bandsaw, with a fence and stop block, to cut the cheeks. I find that to be a faster method for 'production' tenoning.
    For final fitting, I use either the LN or LV shoulder planes, and/or a sharp paring chisel.
    Rio Rancho, NM
    1,417
    On our Woodtek Matchmaker! Cuts mortises and tenons so that the don't have to be individually fitted. Makes life a breeze.
    Nancy Laird
    dandnspecialties@msn.com
    Northwest Indiana
    104
    I've gone over to loose tenon joinery. When I did cut integral tenons I used a tenoning jig on a table saw, with good results. I when over to loose because of the mortise.Too much hand work in cleaning up the bottoms for me.
    There is unrest in the forest,There is trouble with the trees
    For the maples want more sunlight,And the oaks ignore their plea's. N.Peart
    Nov 2007
    Poland
    267
    Nowadays, I use the loose tenon cut on router table but, if the tenon is too long I cut it on the table saw with tenon jig.
    On the pics, you can see my home-made (well, even if I want, I cannot buy it here) that is riding on the fence on wheels (4 side and 4 top wheels).
    I start with a little bit bigger (wider) tenon and than fine adjust it by using business cards of 0.3mm (0.012") for perfect fit.
    Regards
    niki
ID:	22506Click image for larger version.
ID:	22507Click image for larger version.
ID:	22508Click image for larger version.
ID:	22509Click image for larger version.
ID:	22510Click image for larger version.
ID:	22511Click image for larger version.
    Villa Park, CA
    1,407
    If you're making standard tenons (no compound angles), you can cut them on the table saw. A dado blade makes it faster but you can use your standard blade - it just takes more cuts.
    Let's say you want to make a tenon 1.5" long. Use your sled and set up a stop block 1/5" from the far side of the blade (not the side closest to the stop block but the other side).
    Now, set the depth of the cut. Let's say you want the tenon to be 3/8". Figure out how much you need to cut on each side to leave 3/8" in the middle. Raise your blade less than you think you need, and cut just the end of the board. Measure the depth of cut. Adjust blade until you get the right depth.
    BTW, if I want at 3/8" tenon, I make it a fat 3/8" to make sure it fits the mortise and trim with a shoulder plane when I'm fitting. The alternate way is to raise the blade as discussed earlier, but make a cut on both sides and trial fit into your mortise. When the fit is right, use that depth of cut.
    All you have to do now is just keep making cuts until your board hits the stop block. For the sides, I usually make the shoulders the same just so I won't have to re-set anything. Sometimes you can't do that because you want a bigger shoulder on one side.
    This gives a square tenon with square shoulders. To avoid tearout, make sure you have a good backer board. Another reason I make my tenons fat is so I can trim off the saw marks, but with a dado blade they come out pretty smooth.
    For complex tenons, I use a tenon jig.
    Good luck!
    Mike
    Ancora imparo
    Jan 2008
    Lived in Michigan until I retired in Mexico. Build furniture for use. If I need it I build it.
    46
    Could'nt figure out how to put the link in Jeff, but just search "router jig..very primative" in this forumn. I posted it quite a while ago and use the jig a lot. Might just give you an ideal or two. Jerry.
    shaper..
    Nov 2007
    Poland
    267
    Here is Gerald's link
    http://familywoodworking.org/forums/...ead.php?t=9017
    Gerald
    To add a link to your post, open the "link post" and Right click on the address - the address background will turn blue and a drop down menu will appear...
    Choose "Copy" than go to the post that you are replying to and right click at the place that you want the link and choose "Past"
    Regards
    niki
