Results 1 to 10 of 14
Thread: What 220vac outlet/plugs do you use?
    Just curious what is the favored style of 240vac plug/outlet most shops use. My house puts out about 120vac+ on each leg, so I ususally meter 240vac+.
    Im hoping to add either a sub panel or just a couple of 220 breaker into the existing panel so that I can have a few outlets around my shop for my tools.
    Thanks!
    I just found the following pictures online as an idea of what I'm talking about:
    30,002
    I ended up using L14-20 twist-lock plugs and outlets for the 220v circuits in my shop. I don't need (or use) the fourth conductor, but I wanted twist-lock plugs, and found these for a good price on eBay.
    Constantine, MI
    7,887
    I also use a twist lock, but I have my outlets on drops from the ceiling. The connection is about 6' off the floor so I can easily unplug the machine when working on it - like changing blades, etc. I've found that the easier you make it to be safe, the safer you will be.
    www.wrworkshop.com
    11,825
    My lathe uses the 6-30R. I wouldn't call it "favorite", it's just what the plug on the machine needs. Before getting this wired, I thought all 220 plugs and outlets were just like what you see the clothes dryer using.
    "favorite" plug? Whodda thunk it?
    Sacramento, CA
    1,367
    All of mine are Nema 6-20's because nothing needed more amperage than that and they were cheaper than most of the others. A 6-20 will handle up to a 3hp motor. I have found that lots of my friends went overboard on their plugs. Just the other day I saw a honkin' dryer plug on a 3/4hp bandsaw. It works fine - just overkill.
    Jason Beam
    Sacramento, CA
    Indianapolis area
    1,697
    I used the 6-20 for my Shop Fox cabinet saw because the receptacle was there from another application no longer used.
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
    Trinity County - 160 miles north of San Francisco. Redwood forest.
    159
    All 6-20R for my 220v. Four machines are 220, but the first one used the 20-amp plug so I standardized all the rest to that. Even though my 5hp tablesaw could rightfully draw 30amps.
    The circuit in my shop for 220v is 30 amp-rated.
    Thanks for the illustration NEMA codes. Useful stuff to have.
    Gary Curtis
    Floydada, Tx
    1,941
    None of mine are the same. It all depends on what the machine needs. Some only need 20 amps, while my molder draws close to 40 amps when working hard. So this one is on a 50 amp breaker.
    Fort Washington, PA
    180
    I wired the tablesaw, jointer, planer, resaw bandsaw, mill/drill, CNC and my 220 dust collector all with 6-30R. Most of those don't need 30 amps, but I started with that my first 220 machine and wanted to standardize all the 220 when I wired the shop, so they all got the same flavor. If I had to do it all over again, I would have started and stayed with the L14-20 twist lock like Vaughn did. Not that I have had any trouble with the 6-30R pulling or vibrating out of the socket, but just peace of mind that it's secure and locked in. This is especially important on the CNC because lost power if only for a second could result in hours of ruined work (and probably premium wood) if it happened in the middle of a 3D carve.
    Build it Break it Fix it ...repeat
    6-20's on my 20's. 6-30's on my 30's. One thing I do as my outlets are about 40 inches off the ground and cable that gauge gets heavy; I use right angle plugs to take the strain off the cable.
  1. Plugs for Piggy Banks?
    Last Post: 12-17-2012, 12:38 PM
  2. making square plugs
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 11-30-2011, 05:25 PM
  3. Table saw to dryer outlet troubles/Please help!!
    By Craig Johnson in forum New Tools
    Last Post: 11-26-2008, 09:26 PM
  4. Outlet Boxes - Metal or Plastic?
    By glenn bradley in forum Carpentry and Construction
    Last Post: 10-02-2007, 05:07 PM
  5. Proper technique for wiring 220 outlet?
    By Wes Billups in forum Carpentry and Construction
    Last Post: 02-15-2007, 02:59 AM
