Results 1 to 4 of 4
Thread: TS Alignment & "Short fence"
    Nov 2007
    Poland
    267
    Good Day
    I would like to share with you my method.
    I think that almost all table saws comes from the factory "almost" aligned so, I'm using this procedure to "fine tune" the factory "almost"...
    As you'll see, I'm not using any Hi-Tech nor Lo-Tech instruments because every blade has some run-out and flutter and I think that the blade itself "knows" the best if it's aligned or not.
    I'm just "listening" what the blade it "telling" me and correcting accordingly...
    The test must be done with the blade at "full up" position.
    The "test piece" should be of MDF
    Toooooo the pics.......
    Regards
    niki
    On this pic (and the next one), I'm showing the blade stationary which is not the case.
    You should push the test piece past the blade while the blade is running at normal speed and listen to the sounds...
    Nov 2007
    Poland
    267
    17,474
    thank you!!! niki
    for doing what you do so well,, glad you got free of that concret job so you can come back and join in the follies
    Nov 2007
    Poland
    267
    Thank you Larry
    Yes, I finished with the concrete, welding and alike and it took some time till my hands got again smooth (this concrete is making rough hands...) and now I'm back in woodworking...
    Regards
    niki
  1. SIMPLE JIG! turns a "bowl" on "tablesaw"!
    By steve kelly in forum Carving
    Last Post: 11-01-2015, 03:21 PM
  2. "Crime Doesn't Pay" or "No Good Deed Goes Unpunished" ?
    Last Post: 11-21-2013, 05:57 PM
  3. Thompson "V" Versus "U" Bowl Gouges
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 06-25-2013, 01:46 AM
  4. Withdrawn: 50" Vega Table Saw "Utility" Fence
    By Matt Warfield in forum Old Ads
    Last Post: 01-24-2010, 04:40 PM
  5. "new" rip fence for old craftsman TS
    By Raymond Gerdes in forum General Woodworking Q&A
    Last Post: 01-28-2009, 05:11 PM
