Results 1 to 10 of 12
Thread: Maple Orange Bowl
    30,017
    Maple Orange Bowl
    I got an Asturo HVLP mini-gun a couple weeks ago, and finally had a chance to try it out this past week. This is a piece of (just barely) ambrosia maple, about 11" x 2 1/2". Finish is three colors of TransTint dye, followed by a seal coat of spray-can dewaxed shellac, then about 8 coats or so of Ultima Spray Lacquer (USL) from Target Finishes. So far, I really like this stuff. USL is water-based, but it has 100% burn-in, so each layer melts nicely into the previous one. I still need to rub it out and buff it, but I need to wait a week or so. Figured I'd post a sneak preview, and if I get decent pics after it's shined up, I'll post those, too.
Name:	Bowl 049 - 01 800.jpg
ID:	22609 Click image for larger version.
Name:	Bowl 049 - 04 800.jpg
ID:	22610 Click image for larger version.
Name:	Bowl 049 - 03 800.jpg
ID:	22611 Click image for larger version.
Name:	Bowl 049 - 02 800.jpg
    I accidentally labeled the wood as sycamore with the woodburner, and I didn't want to sand it out, so now it says:
    - Not -
    Sycamore
    (It's maple instead)
    Comments, critiques, and opinions are all welcome.
    North West Indiana
    6,098
    Now that is a bowl I could sit down with some pretzels in and enjoy the evening!!! Again, beautiful work!
    Jon
    Goodland, Kansas
    4,834
    Vaughn that is a great looking bowl. Well done. I really like those type bowls. I got to watch a demo by Binh Pho on air brushing. So I bought a airbrush and hopefully I can get some time to try it out also.
    Bernie W.
    Oct 2007
    Harvey, Michigan
    687
    Beautiful bowl Vaughn! Love the form! Really like the way the dye comes up to the edge of the lip but doesn't bleed over to the interior. Gives it a very clean look!
    Not familiar with air brushing - how much control do you have of the spray?
    Steve
    Jan 2008
    Austin TX
    405
    Vaughn,
    Great looking bowl! Do you anticipate any movement in the wood having what I'm assuming are different finishes on the inside and outside of the bowl? I'm still trying to decide how to mark items I make. What are using to mark yours. (Whatever it is I like it)
    Regards,
    Lee Laird
    Austin TX
    30,017
    Thanks for the compliments, all.
    Quote Originally Posted by Steve Schlumpf View Post
    ...Not familiar with air brushing - how much control do you have of the spray?
    Steve, I tried an airbrush on one of these a couple months ago, but the spray pattern was small, so it was hard (for me) to get the shading I was looking for. In the hands of someone who knows what they're doing, I'm sure the airbrush would work fine. They do give the user good control. On this one (and the other one I posted today), I used an HVLP spray mini-gun. Here's the one I have: Asturo Mini-Gun
    Quote Originally Posted by Lee Laird View Post
    Vaughn,
    Great looking bowl! Do you anticipate any movement in the wood having what I'm assuming are different finishes on the inside and outside of the bowl? I'm still trying to decide how to mark items I make. What are using to mark yours...
    This one is finished inside and out with lacquer, so I'm not worried about it moving. The outside does have a layer of shellac under the lacquer (and the dye, which really would make no difference), but even if one side was completely unfinished, I wouldn't worry about movement. Just about any piece will grow and shrink a bit with seasonal changes, but I can't imagine it being bad enough to cause a problem unless it was a real big piece with very thick walls.
    The marking on the bottom are done with woodburning pens. I have one that has a 1/32" ball point on it that I use for all the writing, and another one with a single nichrome wire bent into my "VM" initials.
    Krum Texas
    81
    Another very nice bowl. I just can’t get over how good the dye makes it look!
    Jan 2008
    Austin TX
    405
    Thanks for the info about the possible movement and your "mark". If you don't mind, what type woodburning pen are you using. I don't have anything for that specific purpose but have played around using my soldering station. I'm sure your pen is better suited to the task at hand. Also, where did you get the "VM" and does it fit into the same woodburning handle?
    Thanks again,
    Lee Laird
    Austin TX
    30,017
    Thanks again,
    Lee, the pens I used on this bowl are made by Razortip. For the VM "branding iron", I used their Binding Post Interchangeable Tip pen and bent the nichrome wire myself. They plug into a Burnmaster power controller. I've also tried the Detail Master pens, and use a few of them sometimes, but I've not been real impressed with them. They are fine when they work, but so far two of them arrived DOA.
    Jan 2008
    Austin TX
    405
    Vaughn,
    Thanks so much for the helpful info. Are you using the low end of the Burnmaster line or one of the upper tier units. Quite the range of prices from low to high. I'll have to get one. Just a matter of which one.
    Lee
    Lee Laird
    Austin TX
  1. maple bowl
    Last Post: 07-29-2013, 02:58 AM
  2. 2 recent turnings - maple bowl, square quilted maple platter.
    By Chip Sutherland in forum Lathe Project Showcase
    Last Post: 04-03-2013, 03:22 AM
  3. Maple Bowl
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 09-28-2011, 03:08 PM
  4. Osage Orange burnt bowl
    By Shawn Lakes in forum Lathe Project Showcase
    Last Post: 03-12-2008, 03:38 AM
  5. Osage Orange Bowl
    By Curt Fuller in forum Lathe Project Showcase
    Last Post: 06-03-2007, 07:08 PM
