Results 1 to 10 of 26
Thread: Cyclone - 94dB - building enclosure
    499
    Well,
    I work at a computer for a living and lately I have had web site side work, so I have been sitting in front of a computer WAY TOO MUCH.....
    So Saturday, the wife had a class and I decided I was going to get some more work done on the Cyclone ( it's been a year !!! ).
    I borrowed a dB meter ( Sound Levels ) and measured the Cyclone. It is 94 dB in the middle of the shop. THIS IS LOUD!!!. I wanted to get a baseline measurement.
    My orginal plan had walls around the cyclone. So now I know to be able to use this I have to dampen the sound some.
    So here we go......
    Well you always needs new tools... I have a room to build for my wife very soon and saw the reviews on circular saws. I picked this one up from the Milwakee refurb store. Ended up with good deal since I got the rip fence free.
    This is a GREAT saw. Very heavy duty, a button that locks the blade so you can tighten it with the allen wrench which is included and has a very good holder built into the case.
    Here is the general space that has to be enclosed.
    I took me about an hour of messing around with angles and space to make sure I can get the canister out of the room and get the air compressor from behind the hotwater heater/furnance.
    The ceiling will present a bunch of challenges.
    So That's what I did yesterday. I will add to this thread as I get more time. Should be interesting.
    The db level is the important thing......
    Houston, Texas
    2,323
    Hi Bartee ,
    Db level is very important, to the shop, and the rest of the house. Keep us posted.
    Shaz
    Please join me. Register now.
    Shaz
    Here is how
    Jun 2007
    4,944
    The Sound is Still With You!
    Hi,
    Your cyclone is in the room where you work. You can sound absorb all you want to. However, air going into the DC from your machinery has to exit someplace. If the exit is not outside of your shop, the air coming out of the DC will be going back into your shop CARRYING ALL OF THE NOISE WITH IT.
    You need a way to close the DC off from your shop and yet have the air exiting the DC go someplace else...taking the noise with it.
    My solution was to build a shed outside of the shop. It has a common wall with the shop. It exits air to the outside. The house next door is about 40 feet away from the DC shed wall. (By the way we call it the Outhouse.) My neighbors claim that they do not hear it inside of their house and that it does not disturb them when they have company out on the patio. I hope that is true and that they are not just being nice.
    If they are in the patio I don't use the DC or use it in short bursts.
    My son Glenn has a Delta DC. It is much smaller than mine. He has it inside of his shop. For the sake of his ears I hope he uses it as little as possible (it is a conversation stopper when it is running).
    Even though the above is a bit grizzley I will say
    Enjoy,
    Jim
    VOTING MEMBER
    499
    Jim,
    You are exactly correct...
    My goal is for the surrounding enclosure to absorb some of the sound energy. I know I will not eliminate it.
    As you can see, my shop is in my basement. So I do not have the ability to add on a out building.
    So we shall see....
    Waterford, MI
    773
    I was able to cut about 20dB enclosing mine in a closet just using 2" styro and a 6" thick filter on the air return. I think you can do even better if you get a bit more selective on the sound deadening material and make a baffled air return. Mine isn't objectionable at all noise-wise now. I can't hear it over whatever machine is running. There's pics of the closet build amongst all the other pics in my album on Clearview's site
    http://www.gallery2.clearvuecyclones...s-Mini-CV1400/
    Tellico Plains, Tennessee
    4,351
    I'm not fortunate enough to have a Cyclone, but when I bought my HF DC, I knew I didn't want the noise in the shop... I spent a few years on the flight line of a major airlines, so I've lost a little high and low range hearing and have a constant ringing in the ears... all the other tools are loud enough...
    I put a shed/closet on the end of my shop and set the DC in there.. when it's running I hear a low hum, enough for me to know it's running but not enough to be annoying.
    Chuck
    Tellico Plains, TN
    One problem with having the exhaust exit to the outside is that if your shop is heated or air conditioned you will loose that heated/cooled air while the DC is running. I have filters that are in openings I built between the wall of my shop and the utility room added to the outside. There are some calculations that need to be done to determine the size of the filters and the opening needed to return the proper amount of air. I had help from the DC salesman with that.
    Granted, I am lucky to have a separate room for the DC, but no matter how you build an enclosure you should consider returning filtered air.
    499
    UPDATE: Progress 2" foam and framing
    I spent 5 hours today installing 2" foam board and framing out the basic structure. It just a big closet.
    I picked up 5 sheets of the 2" hardfoam. My approach is to absorb as much sound in the closet as possible. It will never be air tight.
    I simply force fitted large sheets on the two back concrete block walls.
    Then I started the framing. Here the result of today's work. You can look at the web album for all of the other pictures and detailed comments.
    http://picasaweb.google.com/bartee/CycloneEnclosureRoom
    bartee, my dust collector makes the most noise from open blastgates, the air wistlin` through......are you doing this as a premptive strike or have you run pipe and hooked up tools to see if what you are doing is going to help?
    Rhode Island
    800
    Question guys I thought most of the noise came from the motor I didn't even think it came from the air outflow?
    When I get enough money I have a small shed on my house that I keep the garden tools & a basement window right next to the shed I could run a line from the shed through the window to my basement shop. My question is how loud would it be outside of the shed? it's just 2x4 construction with siding on it now?
  1. New controller enclosure
    By Darren Wright in forum New Systems and Builds
    Last Post: 03-17-2016, 11:07 PM
  2. Air flow - generator enclosure help needed
    By Rob Keeble in forum Designs, Plans and Sketches
    Last Post: 12-12-2012, 06:29 PM
  3. Building a cyclone to fit my needs
    By Alan Bienlein in forum General Woodworking Q&A
    Last Post: 07-14-2009, 12:56 AM
  4. PC Enclosure for Dust Control?
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 11-29-2008, 01:18 PM
  5. Building a cyclone (Stu??)
    Last Post: 11-24-2006, 03:35 PM
