Results 1 to 7 of 7
Thread: Making a Donut Chuck
    30,008
    Most of the "how-to" posts have a whole series of pics showing you how to make something. This one will show you how NOT to make something.
    I'm working on a piece that needed a donut chuck to finish off the bottom. It's long and tall enough I didn't want to risk using the vacuum chuck.
    I started out with a round piece of plywood, 18" in diameter. Mounted that on a faceplate, drew some circles, clamped a smaller round piece of scrap particle board to the plywood, and drilled four holes. I screwed the two pieces together, and spun it up on the lathe to cut out the hole in the "donut" part of the chuck. Unfortunately, up to this point I didn't take any pics.
    Anyway, here's how it looked when I was done cutting the hole out of the donut:
Name:	Donut Chuck 1 800.jpg
    No problem, nice clean cut (for particle board). Unfortunately, I had to go outside to pick up the piece that I cut out of the center. It left the shop in sort of a hurry:
Name:	Donut Chuck 2 800.jpg
    Only after I stopped laughing did I go in the house and get the camera.
    If I'm standing at the headstock of the lathe facing the bed, that window is right behind me. But for this cut, I was standing well off to the side (at the back end of a 24" handle with another foot or so of boring bar attached to that), so I wasn't even close to the line of fire.
    I guess you could say I got two donuts for the price of one. The good news is the donut chuck worked fine. The piece finished up nicely, and will be worth replacing the window for. (This one is very special...pics and more story in a few days.)
    564
    Vaughn, that must have gotten your attention. You just never know when something is going to fly off when working on a lathe. Sorry about the window but at least you were not hurt.
    If I were you I would not have the bolts protruding through on the side where you are working. One careless second and your arm or hand could be drawn into a merciless cheese grater. Far better to have the head of the bolt on the side where you are turning. IMHO.
    I may be getting a little older physically but mentally I'm still tarp as a shack.
    30,008
    Quote Originally Posted by Mike Stafford View Post
    ...If I were you I would not have the bolts protruding through on the side where you are working. One careless second and your arm or hand could be drawn into a merciless cheese grater. Far better to have the head of the bolt on the side where you are turning. IMHO.
    Good point, Mike. I agree and do just that when I'm actually using a donut chuck. In this case though, the shortest bolts I had were still a bit too long to clear the headstock, so I put them in backwards, knowing they needed to be watched carefully. That's a lot of the reason I used a long tool from a distance away. I also intentionally had the bolts on the outer edge of the donut, to keep them away from where I needed to cut.
    30,008
    Ya know, it just dawned on me...
    The tailstock would have prevented the whole thing. Doh! doesn't quite cover it. Ah well, I'll know next time. Hopefully someone else will learn from my stupidity.
    Jul 2007
    DSM, IA
    5,719
    Glad you could laugh at it Vaughn....I did too!
    Maybe you should take this opportunity to vent your dust collector outside.
    My Website
    13,433
    Does appear to be about a 6" duct hole, nice clean break too.
    Glad your ok. Might need to see a YouTube of this when you get it working the way you want.
    Vancouver
    191
    Good point! I also countersunk my disks so the bolt end is hidden away for extra safety.
  1. Donut chuck???
    By Tom Baugues in forum General Woodturning Q&A
    Last Post: 07-20-2011, 05:06 AM
  2. Donut Chuck Centering
    By Dawson Mossman in forum Turning Tool Questions and Show & Tell
    Last Post: 05-09-2010, 03:31 PM
  3. Making a Shaftless Pepper Mill - Chuck Ellis
    By Vaughn McMillan in forum Tips and Tutorials
    Last Post: 02-24-2010, 07:22 AM
  4. Donut Chuck used in Scroll Chuck
    Last Post: 12-21-2009, 09:59 PM
  5. Making a Vacuum Chuck System
    By Steve Schlumpf in forum Tips and Tutorials
    Last Post: 02-03-2008, 06:24 PM
