Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
Thread: vac filter problem
    11,835
    vac filter problem
    I have a Shop Vac, 5 hp (that's what THEY call it), 12 gal., hooked up to my bandsaw. It is the only dust collection system I have in my shop. For me, it is important to have it when cutting Osage Orange, red cedar and spalted woods. But, I find that the filter clogs up long before and significant amount of material builds up in the tub.
    Now, I'm conflicted. Use a less fine filter and get dust back into the air I'm breathing or leave alone and put up with an inefficient unit?
    Wat do y'all do?
    Oct 2007
    Schenectady, NY
    912
    Same thing here
    Hi Frank, Mine does the same thing. Since I have the cartridge type filter, I just take it outside, knock out the big stuff, and blow out the fine stuff with compressed air. That is after I have dumped the junk out of the bottom part. None of my shopvacs ever get full before they get clogged.
    Don Orr
    Woodturners make the World go ROUND
    15,809
    What you need is a Mini Cyclone on your vacuum Frank, like the one I built..........
    >> HERE <<
    I just checked, Grizzly does not make one....... yet......
    ClearVue sells a min for your shop vac.......
    >> ClearVue Cyclone <<
    They are $120, but I know a little while back they were on sale for $80
    You can build one, trust me, I did it
    The cyclone separator really works great, next to no dust makes it to the filter........ as long as you don't over fill it
    11,835
    Thanks, interesting. I'll look into that.
    13,468
    Can you get the bags for your shop vacs? I use them in mine, they allow them to run about 100 times longer than without. I've used them in cleaning up drywall dust and can do most of a house (1/4" deep around the walls)without having to change bags.
    http://www.shopvac.com/detail.asp?id=164
    9,077
    I use the $20 cyclone lid from Rockler and have for years. A 5 gallon bucket, a Clean Stream filter, some extra hose and you're all set. The bucket gets about half full and if I'm not paying attention everything will then blow-by into the vac container. I can generally empty the bucket 10 times before I take the filter out and hit it with the hose.
    Orem, Utah
    936
    Couldn't find anything at Rockler. Are you talking about [this Woodcraft offering]?
    Sacramento, CA
    1,367
    I have yet to put together a separator for mine, but I think i may do so one day. Until then, I take my 1/4 sheet sander and a little piece of router pad (those nonslip things) and jitterbug the heck out of the vac (right there on top of the motor). this shakes loose a lot of the clogged debris and buys me another few minutes of vacuuming.
    Jason Beam
    Sacramento, CA
    9,077
    Quote Originally Posted by Kerry Burton View Post
    I'm sorry, I didn't realize Rockler had stopped carrying those. I have the large Woodcraft version (30 gallon trashcan on a 4" hose setup) and it works well. It does put a hit on the DC so I only use it with real chip-makers. The small one doesn't seem to mind as it is a vacuum, not a DC. I think Woodline carries the "Rockler" version without the internal elbow but their site is down right now and I can't check. Sorry again for the misdirect on Rockler.
    I've got the same separator on my shop vac, and I believe I got it from Grizzly, so Frank should still be able to get it from them if he wants.
    It's works pretty well, especially for separating out the bigger chips.
  1. Air Filter Advice
    By Kevin Sadaj in forum General Woodworking Q&A
    Last Post: 10-22-2014, 03:47 PM
  2. Paasche Air Filter
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 05-19-2012, 08:49 PM
  3. Who Would Pay $1000 for an Air Filter?
    By Vaughn McMillan in forum New Tools
    Last Post: 05-17-2008, 02:23 PM
  4. Don't Put Off DC Filter Maintenance
    By Jesse Cloud in forum General Woodworking Q&A
    Last Post: 04-23-2007, 05:35 PM
