Results 1 to 5 of 5
Thread: Wooden Windmill
    Wooden Windmill
    So what sayeth the experts? Do you think its feasible to build a working wooden windmill? By working I mean able to withstand the buffering of the wind, apply power and do something useful with it?
    Everyone knows on here that I am a machinist and can weld and fabricate, but even at the price my company pays for steel, its kind of prohibitive for an all steel windmill. I was thinking of making the majority of my windmill out of wood and then using steel for only the parts that really need to be steel.
    I was thinking of building a verticle axis windmill (VAWM) and then building the tower out of wood as well. Maybe a 16 foot section 8 x 8, then another section 16 feet high 6 x 6, and then a final section 16 foot section 4 x 4 so it was 48 feet high in all.
    As for the "work", I really don't need electricity. What little bit it would produce would do very little to drop my electric bill. Instead I would like to do something with heat. I had two ideas really. Coupling the windmill so that it was running an air compressor. I could use the air inside my shop, but more importantly I could encircle the compressor with water tubes and run that water into my radiant floor heating system (low temp water).
    Another idea is to use the windmill to run a plunger. This plunger would compress hydraulic oil out through a relief valve. Squeezing that oil through such a tiny orifice heats oil up very fast. If I take that hydraulic oil and coil the hydraulic line inside a water tank, it should heat the water up as well. I could then transfer that heated water to my radiant floor.
    So what do you think? Would a wooden windmill work, and would some of my ideas for converting mechanical motion into heat energy also work?
    North West Indiana
    6,099
    Travis do you get or have you ever seen the magazine "Farm Show"? It is a magazine about farmer built inventions. Saw a farmer utilizing 50 gallon barrels and collecting the methane. For some reason, thought of you while reading that!
    Jon
    No I haven't seen that show.
    You probably thought of me because of last years Thread on compost heat. I must admit of all the things I have thought of to heat my home, I keep coming back to that because it will make heat 24/7/365 without needing the sun to be up, cloudless skies or windy weather.
    13,460
    My wife's grandfather heats his place using one of those outdoor stoves. Looks like a big stainless steel box, but the water circulates through it to the baseboards in the house, also uses it for the hot water in the house. He puts two or three logs on it every day, which is enough to do both. For the summer time he's got a natural spring that is behind the house with the water coming out at 50 degrees (F). He gravity feeds it to the house and circulates it through the same baseboards. Never seen his house when it was uncomfortable. Last I checked he had a solar panel charging a battery that was running the pump.
    Hempstead, Texas
    80
    Quote Originally Posted by Travis Johnson View Post
    Travis,
    You could use it to aerate a pond, if ya got alot a fish in it.
    What I would like to do is build a wood water tower or a water tank.
    I have thought of wanting to build a wood water tank for rain water, to water the yard and garden but finding free plans has not givin to many results.
    Here are some links for ref:
    http://www.texaswindmills.com/
    for Parts:
    http://windmills.swnebr.net/
    Good Luck
    Ted
  1. Wooden Car
    By Dan Mooney in forum Flatwork Project Showcase
    Last Post: 08-26-2014, 03:45 PM
  2. really big wooden guitar
    Last Post: 10-15-2013, 07:25 PM
  3. Wooden railing
    By Milan Misko in forum Lathe Project Showcase
    Last Post: 07-07-2013, 08:40 PM
  4. Exploding Windmill Video
    Last Post: 06-04-2009, 11:54 PM
  5. Wooden Hinges - How To
    By Alex Reid in forum Tips and Tutorials
    Last Post: 02-01-2008, 12:52 PM
