Results 1 to 10 of 12
Thread: 10" Tablesaw Blade, 1/8" kerf, Flat-top Grind
    Jan 2008
    Jay, Maine
    120
    Thumbs down 10" Tablesaw Blade, 1/8" kerf, Flat-top Grind
    Can anyone recommend a blade that meets the criteria in the subject? I only have a couple of blades but they are both 3/32" kerf with ATB grind and they don't work well for creating miter key slots for box edges or for 1/8" finger joints. Just wondering if anyone has such a blade and, if so, how they like it. Cost IS an object here, too - preferably $50 or less.
    Thanks.
    Jim
    9,035
    I just got the TK version of this. The full kerf version ($59) should be about 1/8". I make all my keyslot cuts and then move over a smidge and do them again. I also have a carriage for small boxes that I run over an 1/8" bit on the router table.
  3. Quote Originally Posted by jim crockett View Post
    Thanks.
    Jim
    Jim,
    As Glenn said, the LM72R010 is an excellent example of the type of blade you need. The cuts you described are rip cuts so a rip blade is called for and this one has the flat teeth and 1/8" kerf you are after.
    Houston, Texas
    2,323
    Hi Jim ,
    Good input from these guys. Good luck.
    Shaz
    Please join me. Register now.
    Shaz
    Here is how
    Central CA
    797
    Quote Originally Posted by Charles McCracken View Post
    Jim,
    I use this blade for the same use and it is awesome. Perfectly square kerfs. It's a great blade.
    Thanks, Mark.
    Custom Bonehead.
    My diet is working good. I'm down to needing just one chair now.
    "Just think how stupid the average person is, and then realize that half of them are even stupider!" --George Carlin
    Jul 2007
    Grove City, Ohio
    57
    I use an old Makita miter saw blade for splines. It is a 50 tooth blade that is flat ground and full kerf. I paid about $40 for it a few years ago. Not sure what the model number is.
    For box joints I use the Freud box joint blades.
    Rochester
    838
    Hi Jim - Any of the better full kerf FTG rippers should do well. The LM72 is an excellent example but may exceed your budget. Amazon has the CMT on sale just within budget, the Infinity ripper should be close in price and is also a great blade, if you can find a DeWalt DW7642 or DW7124 ("Series 40", not "TK", and not the yellow "Precision Trim" series) either of those will work well and should be within budget. You might find some of these on Ebay too...worth a look.
    Got Wood?
    Jan 2008
    Jay, Maine
    120
    Thanks, guys. I didn't realize that most (all) rip blades were FTG - learn something every day!
    I did some checking and found the Freud LM72M010 for a little over $30 - same blade as the LM72R010 except it has the Silver Ice Coating instead of the Perma Shield Coating. I would think that it should work nearly as well and the $25+ saved makes it a little easier to justify.
    Anyone using the LM72M010 and, if so, what are your thoughts?
    Thanks again - love this group... you guys are always so helpful!
    Jim
    Central CA
    797
    I have a couple of identical blades with and without the Red coating. I find that on deeper cuts they are a tiny bit cleaner from the blades with the Red coating.
    Thanks, Mark.
    Custom Bonehead.
    Rochester
    838
    That's a great price Jim...care to share your source?
    I had an LM72R010 a few years ago but the full kerf was a bit much for my saw at the time if I was sawing very thick dense material. The LU87R010 is the TK version of the same blade and was great on my 22124. Now that I have a 3hp saw, I'll probably end up looking for a full kerf ripper for it.
    Got Wood?
  1. SIMPLE JIG! turns a "bowl" on "tablesaw"!
    By steve kelly in forum Carving
    Last Post: 11-01-2015, 02:21 PM
  2. MICRO-KERF 40 10"
    By Doug DeVore in forum New Tools
    Last Post: 01-21-2012, 08:31 PM
  3. Replies: 31
    Last Post: 01-26-2009, 08:10 AM
  4. Replies: 1
    Last Post: 07-16-2008, 11:21 AM
  5. How far can we take " kerf " ?
    By steve mackay in forum Neander Tool Questions and Show & Tell
    Last Post: 09-05-2007, 05:38 PM
