Results 1 to 10 of 27
Thread: the C1 tool
    11,825
    the C1 tool
    I have seen this discussed here but never really knew what it was. Looks like the end-all to lathe tools needed. I'm going to throw away all my lathe tools and make one of these.
    Actually, I do plan to buy a set of the cutters and make one for myself. About $30.00 for ten cutters put on a homemade handle is a lot cheaper than $99.00, or more, from CS.
    Watch the video. http://www.easywoodtools.com/
    Alexandria, Virginia
    1,071
    I'll tell you Frank this tool is the end all to end all. I can clear out the inside of a 8" wide x 3" deep bowl to where I just glide the bowl gouge before sanding in about two to three minutes. It cuts wood like a hot knife through butter.
    When you throw out your old tools, please throw them my way.
    11,825
    Been thinkin'. I do that sometimes.
    Why does the shaft need to be square?
    A 1/2" round with the flat cut to receive the cutter would/should work just as well and be easier to seat in a handle.
    1,071
    I think it is square so it sits on the tool rest with the cutting edge square to your work. With a round shaft you may catch an edge and this cutter will bite.
    30,002
    Where are you finding cutters for $3.00 each? Be aware that there are different profiles of carbide inserts out there...and not all of them will give the same results as the Ci1. I know this, because I have a couple of other similar "carbide insert" tools, and I have a Ci1. Dunno what the Ci1 does differently, but it most definitely cuts differently (better).
    The square bar is indeed an improvement over a round bar. Here again, I have both, and the square bar requires less work to use. With a round bar, you're always fighting rotational forces with your wrist; the square bar just sits flat on the tool rest and lets you cut.
    11,825
    Not having ever used square, I won't debate. Square sounds good to me.
    Try this link, I have written them asking the size.
    http://www.sunhillmachinery.com/stor...p?department=5
    1,071
    Frank, I have had lots of luck with Speedy Metals. I recently bought Stainless Steel in square stock. No minimum for size or quantity; they are also on eBay.
    11,825
    11,825
    Quote Originally Posted by Frank Townend View Post
    Looks good. I would probably go with plain ole cold rolled steel bought from a local supplier. But, good source for lotsa stuff, I'll save the link.
    Drums, PA
    292
    Get the matching screws, they need to have the correct taper.
  1. Tool cabinet Tool Chest what belongs what dont
    By Rob Keeble in forum Neander Tool Questions and Show & Tell
    Last Post: 10-28-2013, 05:32 PM
  2. Greate Tool Database Site - with Tool Give away contests
    By Fred Stellabotte in forum Giveaways, Contests, and Swaps
    Last Post: 05-18-2013, 01:36 PM
  3. Replies: 1
    Last Post: 08-26-2010, 01:18 AM
  4. **SOLD** Pro-Forme Tool Hollowing Tool Set
    By David Propst in forum Old Ads
    Last Post: 03-30-2008, 03:08 PM
  5. free , tool lasso tool holder from Werner
    By skip coyne in forum Hot Deals
    Last Post: 12-28-2006, 12:52 AM
