Results 1 to 10 of 10
Thread: busted casting...
    5,533
    busted casting...
    Moved the lathe into the shop tonight, and discovered this:
    Looks like the other three bolt holes will have to take up the slack for that one.
    -Ned
    Orem, Utah
    935
    Ouch!
    This is on the left rear corner of your Delta Midi? That's too bad ... that's the hole I use to store my knock-out bar.
    I have yet to bolt down my Delta Midi ... but I tend to turn smaller stuff, and I do have an extension bed which adds to the weight.
    5,533
    Kerry, yep, left rear, and I too have the bed extension, so all is not lost. I've still got to get the other bench assembled. I"m treating it like the 'first dent' on a vehicle.
    -Ned
    30,002
    Sorry to see the ding, but it sure shouldn't hurt the operation, though. All the time I used my little Wilton mini (including now, as a buffer for small pieces), I never did see the need to bolt it down.
    That is surely not going to affect the lathe much, if need be, maybe Kerry can weld you a new piece on there
    5,533
    Ohhhh, I think that getting out to effect the repairs might up the cost on that solution there Stu... but you knew that...
    I'm probably going to build up the area with some JB weld, redrill it, but only if I find the lathe isn't stable when I start turning.
    -Ned
    All of the above answers... as contrary to popular belief You can weld cast iron. A washer and the broken piece will allow a good clamp down, and little need for bolting down if you put down a rubber mat under the lathe (like those tool box liners or puffy rubber shelf liners.)
    5,533
    Bill, I happen to have an ample supply of router mat, aka rubber placemats on hand, from when I brought home my canoe a few weeks ago.
    I haven't located the broken piece yet, but I only remembered to check the likely scene of the damage after I buttoned up my storage unit and was driving home this evening.
    -Ned
    30,002
    Ned, I assure you that if the three remaining bolt holes won't hold down that lathe, then you're turning a way too big (or unbalanced) piece on it. Or you're pushing too hard with the turning tools.
    5,533
    I'll trust you on this one guys, but it's nice to know I have options!
    -Ned
  1. trying my hand at casting
    By John Daugherty in forum Lathe Project Showcase
    Last Post: 06-03-2013, 11:16 AM
  2. My First PR Casting
    Last Post: 05-18-2010, 03:11 PM
  3. I think I busted myself!
    By Toni Ciuraneta in forum Off Topic Discussion
    Last Post: 09-03-2008, 06:56 PM
  4. Busted Chairs..........
    Last Post: 02-27-2008, 10:06 PM
  5. Jiffy Lube Gets Busted
    By Boyd Gathwright in forum Off Topic Discussion
    Last Post: 02-01-2007, 03:49 AM
