Results 1 to 10 of 13
Thread: Bois d'Arc Box
    Tyler, Texas
    336
    Bois d'Arc Box
    I made this for a lady who really admires my turnings. She's especially fond of the look of Bois d'Arc and the smell of Cedar...so I combined the two.
    Lidded Bois d'Arc box with Cedar lining. About 2 1/4" x 2 1/2", sanded to 12,000 MM and buffed with Carnauba.
    Attached Thumbnails Attached Thumbnails Boisd'ArcBox 001.jpg   Boisd'ArcBox 002.jpg
    Cody
    Orem, Utah
    935
    Cool! Nice job on fitting the cedar insert.
    30,017
    That's slick, Cody. She got two boxes for the price of one. Is that a rubber o-ring on the lid?
    Tyler, Texas
    336
    Nah, just a burned ring. Thanks for the comments.
    Cody
    Cody, that is really slick, I saw an article on how to do that insert thing in a magazine a while back, looked interesting but exacting, how did you find it?
    Tyler, Texas
    336
    Stuart, I found it not hard at all. I just turned the box with straight sides and a square corner at the bottom...I used my parting tool to square it up after doing most of the hollowing with a bowl gouge. In hindsight, I could have just drilled it out with a Forstner bit. That's what I will do on the next one.
    Next, I chucked up a blank of Cedar a little larger around and a little longer than the box I.D. I turned it down until it just fit inside the box opening...not quite a suction fit but close. Then, I mixed up some epoxy and epoxied the Cedar inside the box.
    After the epoxy dried, I hollowed out the Cedar, leaving it about 1/8" thick. I shaved down the outside of the box until the Bois d'Arc was about 1/16" thick, cut a recess for the lid, shaped the lid and turned a tenon on it with a friction fit.
    Then I sanded it all to 12000 MM, burned the lines and turned the bottom. That part is the easiest because the box can be placed over the chuck jaws and they can then be expanded to hold it while turning the bottom. I filed away those two little rings on the Talon jaws so that it wouldn't leave a mark when expanded that way.
    I can envision the box sitting on the lady's dressing table or bedside table so I cut a recess in the bottom and glued a piece of 1/8" thick cork inside. The cork extends just enough to keep the box from touching whatever it is sitting upon, preventing scratches.
    Dat's it. It actually sounds more involved than it was. I plan to do some more...when I get home. I have to head back offshore tomorrow for 14 days at work.
    Y'all keep turnin' so I'll have something to look at out on the water.
    Cody
    Jan 2008
    Austin TX
    405
    Cody,
    Cool little box. Thanks for the nice how-to.
    Lee Laird
    Austin TX
    Krum Texas
    81
    That’s a cool little box Cody. Did you have any trouble with the odor of the epoxy overpowering the cedar?
    Goodland, Kansas
    4,834
    The box is a beauty Cody and I like the cedar insert.
    Bernie W.
    Retirement: Thatís when you return from work one day
    and say, ďHi, Honey, Iím home Ė forever.Ē
    Tyler, Texas
    336
    Quote Originally Posted by Shane Starnes View Post
    Thatís a cool little box Cody. Did you have any trouble with the odor of the epoxy overpowering the cedar?
    No odor once the epoxy dried.
    Cody
  1. Bois d'Arc bowl
    By Mark Cothren in forum Lathe Project Showcase
    Last Post: 11-26-2009, 09:08 PM
  2. Bois d'Arc Hollow Form
    By Cody Colston in forum Lathe Project Showcase
    Last Post: 06-25-2009, 07:04 PM
  3. Bois d'Arc Hollow Form
    Last Post: 09-22-2008, 09:05 PM
  4. Bois d' Arc Bowl
    Last Post: 08-21-2008, 02:31 AM
