Results 1 to 10 of 13
Thread: A Coring I -- I have GONE!
    Today the post man delivered a box from the US, from Ray Klosek who sold me his slightly used McNaughton Coring rig
    The box survived the trip, but it sure got damaged..........
ID:	23285 Click image for larger version.
    ...thankfully, Ray took the time to wrap everything very well, so it all arrived in fine condition.........
    Now I just have to finish that wall, then I can maybe play in the Dungeon!
    30,017
    Congrats. Be careful taking the tape off the tips of the knives. They WILL cut flesh. At least mine did.
    Mason Michigan
    455
    Congrats Stu!
    Please let me know if you figure it out. I have two videos and I still can't figure what to do.
    "Small Change got rained on with his own 38"
    Tom Waits
    Well, I'm painting today, so I'll not get a chance to take it for a test ride, but I did watch the DVD while the first coat was drying, and it looks quite straight forward to me.......
    Last famous words.......
    Tyler, Texas
    336
    Congrats and be sure to give us a full review when you've put it through it's paces. I've read lots of negative things about that coring system but Bill Grumbine thinks it's the bees knees. I certainly believe Bill but he could make anything work that has to do with turning.
    Looking forward to your impression.
    Cody
    Yeah, I should get the DVD that Bill does on it, I have the Mike Mahoney DVD, and it all looks fairly straight forward to me
    Goodland, Kansas
    4,834
    Congrats Stu. Can't wait to see some bowls out of it.
    Bernie W.
    Well, I gave it a test drive today, this is not your father's Buick
    I can see there is a learning curve here, some work to be done and some more practice needed, but..... I can see how this thing works, now I just have to get some more time on it, and read up some more, ask some questions and such, but it works!
    I have a lot of lousy blanks I've not turned, as I figured they would only be good for practice and for this, they will work fine!
    I started out with this chunk of wood, some Ginko that I got in December of 2006. The wood is dry and punky, not much good for anything really, well, except for practice
    See that large chunk of bark sitting there, well it came off the blank at about 1500 RPM and smacked me dead center in the face........ face shield...... as I had my Triton Power Respirator on, I'm sure glad I always where that thing when roughing out!
    I got the basic shape done, and left a nice big tenon on it.....
    First set of coring, the look not bad........
    ....... that is until you see the other side....
    I went way too deep on the first smaller bowl
    Here is my second try....
    No funnels this time around, but there is a lot more work to be done.
    At least I have a LOT more blanks to practice on
    30,017
    Nice funnel collection. Hopefully you got them all out of your system now.
    I'm planning to use up some more of my dried and somewhat punky alder for the same purpose. I'm looking forward to trying it on some fresh, green wood. Aside from my first couple practice sets with dry wood, I've not done any more. I've been concentrating on finishing up other pieces in preparation for the fall show season. I have rough cores sitting around that I don't intend to finish.
    I have used a couple of the rough cores for jam chucks on a couple pieces I was finishing. Used with the face pointing to the inside of a bowl, jammed into place with the tailstock, they help reduce vibration when doing any finishing cuts on the outside. Or, chucked up on the headstock, they can be used when reversing the piece to trim off the tenon. I used one on the maple bowl I just posted about. It was too deep for my vacuum chuck, plus it has a crack though the bottom due to a knot, so the vac chuck wouldn't work anyway. I just reversed the walnut bowl into the face of a roughed-out core on the chuck, and turned the tenon down to a nub. Then I sawed and sanded the nub down to finish the bottom.
    Goodland, Kansas
    4,834
    Well Stu now that you have got the funnels down pat it is time to make some bowls. Looks like you are on your way bud. Keep'em coming.
    Bernie W.
  1. WTB Mcnaughton Coring System
    By Raymond Sprouse in forum Old Ads
    Last Post: 07-15-2011, 10:16 AM
  2. Coring
    By Paul Gallian in forum General Woodturning Q&A
    Last Post: 12-02-2010, 08:42 PM
  3. A couple more from the coring tool
    By Mark Pruitt in forum Lathe Project Showcase
    Last Post: 06-17-2009, 10:03 PM
  4. Homemade coring rig video
    By Jeff Bower in forum General Woodturning Q&A
    Last Post: 06-11-2009, 01:57 PM
  5. McNaughton coring system
    By ray klosek in forum Old Ads
    Last Post: 08-10-2008, 06:22 AM
