Results 1 to 4 of 4
Thread: Bread board end attachement
    The Heart of Dixie
    4,268
    What is the proper method(s) for attaching bread board ends? Cherry about 24" wide top.
    I have read glue the center and then drive dowels in the near the ends with slightly oversized hole in the tongue.
    Custom built boats and Kits
    Constantine, MI
    7,890
    This is the way I've done it. The current issue of Wood magazine has a step by step picture tutorial on BB ends.
    www.wrworkshop.com
    I do this if I am using end plugs for decoration (the screw part, not necessarily the end cap):
    5,320
    Depends...
    If you're building a piece of furniture that'll sit against a wall (dresser, china cabinet, etc.) then you might want to consider gluing the very front, and 'loose dowelling' (a slot in the tongue) the center and back. That way, the front edge will always be even,
    If it's a table or other piece that will sit with all edges exposed, then your method of center glue/pin and loose dowels at each end is the way to go.
  1. Whole Wheat Bread in a Bread Machine....?
    Last Post: 11-27-2010, 12:02 AM
  2. New TS Fence w/Router Fence Attachement
    By scott spencer in forum New Tools
    Last Post: 05-21-2009, 08:31 PM
  3. Check your bread.....Bread Recall (This one is not a joke)
    By Mark Rios in forum Off Topic Discussion
    Last Post: 07-29-2007, 01:10 AM
  4. Small Cutting Board & Bread Knifes
    By Aaron Beaver in forum Flatwork Project Showcase
    Last Post: 02-26-2007, 02:10 AM
  5. Woops-Bread board ends/wood movement
    Last Post: 12-30-2006, 09:33 PM
