Results 1 to 10 of 21
Thread: momentous occasion...
    5,533
    can you identify that?
    you guessed it... first shavings in the shop from the spinny thing!
    -Ned
    Constantine, MI
    7,887
    Oooooooooooooooooooo
    We all die. The goal isn't to live forever; the goal is to create something that will. - Chuck Palahniuk
    www.wrworkshop.com
    3,134
    It'll never be the same.:
    Goodland, Kansas
    4,834
    Holy Cow Ned is a turning.
    Bernie W.
    Orem, Utah
    935
    Woo Hoo! Delta Midi owners unite!
    Have fun out there, Ned!
    Ned,
    Carefully scoop those shavings up and put them in a jar - put the jar in a special place. Maybe they'll have baby shavings like the last two dollars at the Bailey Building & Loan Association!
    Good to see!
    Wes
    Jul 2007
    DSM, IA
    5,719
    Woooooo Hooooooo! Just don't fall into the same hole Ken F. did with his mini before his shop was finished....what I'm trying to say is.....
    STOP what your doing and finish the stinking shop already!
    My Website
    DITTO!
    Once you get sucked down into that vortex it is really hard to get out............ trust me!
    11,825
    Beautiful shavings.
    Actually, enjoy the lathe.
    5,533
    Well guys,
    That was truly just a test run. I can't let the lathe get in the way of the shop completion, I've got a firm date to clear my storage unit, and I've got a ton of juggling to do before I'm done.
    I also need to get my turning tools tuned up, and/or pick up a bowl gouge, I only have two spindle gouges in this set at the shop, which I believe are just HF HSS tools.
    that's how both of the gouges were sharpened, and while they cut, I was very aware of those points out there just waiting to catch.
    I do have another set of tools, carbon steel ones which are over at Mark's shop, that set has a bowl gouge, so I guess I'll be going to Oneida at some point.
    I also got my bandsaw up from the storage unit, and man that sucker is Heavy. Sean whom I indirectly bought the saw from built a Massive base for it out of MDF.
    I got that up and running as well last night, and it works like a charm. I will need to pick up a couple more blades, time for a call to Suffolk, but that will have to wait for another paycheck.
    another new tool in the shop is this generic little grinder, price was perfect: Free
    I need to get a finer grit wheel to replace that wire wheel, but it works just fine.
    -Ned
  1. I don't rant often but....on occasion.....
    By Ken Fitzgerald in forum Off Topic Discussion
    Last Post: 01-15-2012, 10:07 PM
