Results 1 to 6 of 6
Thread: Life is just a Bowl of Cherry
    30,233
    Here's a cherry bowl I finished recently. It's my first cherry bowl; I turned it from dried stock. After all the interesting grain I've been seeing in the red eucalyptus I've been playing with, this cherry was pretty boring. It turned nicely, though, and being dry already, I was able to get a bit more instant gratification. This was my first time of intentionally using a glued-on tenon. (I glued a tenon on an earlier bowl after breaking off the original one.) I also intentionally tried to stay with a more traditional utility bowl shape, which was a first for me. It'll make somebody a good M&M bowl.
    It's about 3" tall by 7 1/2" wide, sanded to 400 grit and finished with a few coats of wipe-on poly and buffed.
Name:	DSC_1360 Cherry 1 C 800.jpg
    It's a little wide on the bottom, but I guess that'll make it less likely to spill the M&Ms.
Name:	DSC_1363 Cherry 1 C 800.jpg
    Comments and critiques are welcome, as always...
    15,815
    Nice, I'd not call it "Boring", sure, the figure is not there of the other stuff, but that is one nice bowl, perfect for a handful or two of whatever you want to snack on.
    I like it!
    Kutztown PA
    252
    Very nice Vaughn, and while it might look a little uninteresting now, wait a little bit and see how nice it looks as that deep red cherry color takes over!
    Bill Grumbine
    www.wonderfulwood.com
    Houston, TX
    363
    Looks good Vaughn, and like Bill said, wait until it turns and it will look even nicer.
    Goodland, Kansas
    4,834
    That is a real beauty Vaughn. Nice work.
    Bernie W.
    Central Illinois
    936
    Nicely done, Vaughn.
    Bruce
  1. More about a way of life than bowl making...
    By Bill Satko in forum Off Topic Discussion
    Last Post: 10-14-2012, 01:17 AM
  2. Cherry Bowl
    By Ted Calver in forum Lathe Project Showcase
    Last Post: 04-11-2012, 12:22 PM
  3. Cherry Bowl
    By Dennis Kranz in forum Lathe Project Showcase
    Last Post: 05-10-2010, 03:00 PM
  4. cherry bowl
    Last Post: 08-15-2009, 11:58 AM
  5. Cherry Bowl
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 04-07-2009, 03:05 AM
