Results 1 to 4 of 4
Thread: Modified my panel sled...
    5,533
    Thanks to Larry....
    I had a little free time today at the house... (copmuter problems on the work machine, so I'm sitting home twiddling my thumbs)
    After picking up scraps and sweeping out the shop among other little things (didnt' want to get into anything too involved, in case I had to drop things and go to w***), I decided that I would listen to Larry's advice not too long ago, and put a block on the back of my crosscut sled. It was just something quick and easy to do, so it ain't pretty, but it is there ,and I'm sure it will help.
    I'm planning on making a much smaller crosscut sled in the 'near' future, but there's a lot more stuff in the storage unit yet to come home, so it may be awhile.
    -Ned
    17,475
    By george!!!!
    He does listen i know of guy that wished he had that option on his a few years ago.. and if you get aoutfeed table set up have it stop your sled before going threw... if i get time i will try to get a pic or two to explain better. safty should be no.1 in any shop large or small. and belive me i anint no angel
ID:	23391shows the blade buried in the fence and back block
ID:	23392 back block
ID:	23393stop block attached to fence
ID:	23394stop block engauged in the outfeed table mitre slot
    Cedar Park, TX
    320
    That stop is a great idea. I've got a second thickness of material on mine, but nothing but my attention span to prevent me from cutting through it and into what ever appendage might be in line with the blade as it comes through.
    Jerry
    Nov 2007
    Poland
    267
    I also made some kind of "travel stops" so, I don't push too much nor pull too much...
  1. Modified Cigar Pen
    Last Post: 06-29-2013, 10:30 AM
  2. Modified Atlas Pen
    By Ron Hossack in forum Lathe Project Showcase
    Last Post: 06-11-2011, 02:59 PM
  3. Modified Rifle Casing..............
    By Les Elm in forum Off Topic Discussion
    Last Post: 02-16-2011, 10:59 PM
  4. Modified Olympia
    Last Post: 01-25-2011, 03:52 PM
  5. Sabbatical is modified
    Last Post: 12-12-2010, 03:48 PM
