Results 1 to 6 of 6
Thread: Flip Top - Revisited
    Discussions about flip top cabinets resurface now and then. I had decided to change from four locking swivel casters to two swivel and two fixed. As long as I had the machines off the table I thought I would get some better shots of the cabinet itself. Hope this helps anyone planning or building.
    He looks kinda flimsy unloaded but it is quite sturdy:
    I had to modify the caster stand-offs to accept the new caster layout but they are still hidden by the skirt:
    Here's the eye-bolt table-top lock idea I stole from some brilliant person whom I can't recall (I just know it wasn't me):
    Another shot of the latch/lock:
    A view of the top-sandwich. I made mine thicker than most recommended plans I saw. This allows one side of the the top to be removable so I can change t-nut locations or add through bolts:
    Here's a shot of the side with the screws:
    I have flipped this thing hundreds of times and with a little thought about placement, the various tools I have used it for flip without much effort at all. It currently holds my 80lb planer and a 60lb sander.
    OK, I'm on a roll out there so, it's back to the shop!
    37 5'16.25"N 7625'28.11"W
    193
    I recently used Glenn's methods to build two flip tops, should have done it years ago! One holds my Delta 22-580 planner and Dewalt 735 CSMS, the other holds the bench top mortiser on one side and is a flat work area on the opposite side. I'm planning a third for a couple of grinders and sharpening stuff on one side and a 42" X 1" sander on the other too. Glenn's method of securing the top with eye bolts is slick and very secure, once locked down it's rock solid.
    I found solid metal knobs at Enco for only $2.14 ea which I think is an improvement over the plastic ones.
    http://www.use-enco.com/CGI/INSRIT?PMAKA=240-0766
    Mike
    30,017
    Very slick, Glenn. If I had the floor space, I could use one or two of those myself. As it is, I set the tools like my planer or mortiser on a bench, on the MSUV in the driveway, or on top of the table saw. I don't have the room for another box in the shop right now. I'll definitely use this idea if and when I move into a bigger shop someday.
    Great Idea, but when you flip it over, doesn't all the dust and chips fall out? I don't know about you, but it takes me a considerable amount of effort to get my piles of dust, just right.... Seriously, on that line, did you consider a bin of sorts to catch the chips and dust that Will fall out, for easier cleanup.
    I especially like your "latches" should make for a secure positioning.
    Thanks for the posting
    Quote Originally Posted by Bill Simpson View Post
    I hook the DC to the planer and a triggered shop vac to the sander. there's not a lot of dust to dump . . . at least from those two tools . Now the small bandsaw . . . I gotta build a vac hookup for that baby .
    I guess in the 70's they thought that hole in the bottom of the housing was adequate(?)
    Catalunya
    4,632
    Great idea Glenn.
    I've never thought about it and I think I'm going to use it at my shop, it will spare me the hassle of setting up a machine each time I need it.
    Thanks for posting!
    Best regards,
    Toni
  1. Quick Flip Stops - Shop Made
    Last Post: 08-17-2015, 12:16 AM
  2. Flip stands
    By Carol Reed in forum Jigs and Fixtures
    Last Post: 11-22-2013, 10:49 AM
  3. Flip Top Has Nine Lives
    Last Post: 04-21-2012, 06:57 PM
  4. Flip Down Casters For A Workbench
    Last Post: 04-30-2010, 09:15 PM
  5. Flip Your Benchtop Tools Down and Out of the Way
    By Bill Satko in forum New Tools
    Last Post: 08-01-2009, 10:15 PM
Tags for this Thread
