Results 1 to 2 of 2
Thread: clue-less vinly flooring?
    Floydada, Tx
    1,941
    My best freind(Mr. Cheap-Cheap skate) found a really good deal on some vinly flooring that is supposed to be help in place by just using two sided tape on the edges. Anyone ever use or hear of this stuff? Does it really hold up as well as glue down stuff?
    5,321
    There are some vinyls that only require edge gluing, instead of 'full field' gluing.
    A few months ago, I re-did a fifteen year old bathroom floor that was edge glued, and it had held up very well - no pulls, wrinkles, etc. at all. In fact, I didnh't know it was only edge glued untill I started to remove it.
    Not sure about edge taping, though. I guess that, with the proper tape, it's be okay. They do use DF tape for carpeting...
  1. oil stains from vinly clamp pads
    Last Post: 03-20-2011, 03:42 AM
  2. Red oak flooring
    By Al killian in forum Old Ads
    Last Post: 01-15-2011, 09:19 PM
  3. Vinly/ pvc trim stock?
    By Al killian in forum Carpentry and Construction
    Last Post: 04-11-2009, 03:54 AM
  4. Shoppers without a clue!
    Last Post: 12-28-2008, 02:25 AM
