Results 1 to 10 of 10
Thread: 12345
    NH
    4,005
    12345
    12345
    Stupid hurts.
    17,471
    what about cyprus chuck?
    11,828
    Redwood, Osage Orange, Black Locust.
    Black Delrin will last near forever. Don't try glueing it. I get mine from Cope.
    http://www.copeplastics.com/docs/index.html
    Jan 2008
    Stow, OH
    151
    How about those man make decking material? Will 5" (6X6) actual size work? You may be able to get the cut-offs from job sites.
    Gordon
    Orem, Utah
    935
    Questions:
    1) What is fiphon?
    2) 6" x 6"? That sounds kinda squat ... will this be more like a [mortar] than a classic "pirate ship cannon"? (If so, check out [this interesting page].)
    Sounds like a cool project. Good luck, and let us know what you learn about turning plastic (if that's what you end up going with). Oh - and don't forget to take pictures!
    Orem, Utah
    935
    Kerry it is only the end of the cannon barrel it is going to be bolted to the side of a van.
    O, I C ... this gets more interesting all the time!
    Chuck,
    How about high density polyurethane like Butter-Board or Ren Shape? I know they would turn better than a lower density urethane like Fypon. I have made prototypes with Butter-board, and it does turn like butter! Takes a finish well too.
    FWIW, Wes
    Inside the Beltway
    2,666
    Chuck,
    I've got some black locust just sitting taking up space in my shop...
    Bill
    Grand Rapids, MI
    383
    Interesting Option
    I don't know if it's possible with a blank that big, but there is a guy around here who stabilizes pen blanks and sells them at Woodcraft. Basically the wood is impregnated all the way through with some type of acrylic or epoxy/plastic whatnot.... Anywho, the point is that they most likely would be weatherproof. Maybe you have someone in your area who can do this??
    Hutch
    Catalunya
    4,632
    Hi Chuck.
    PU rigid foam comes in different densitys and thicknesses. Easy to glue, easy to work and light weight. ( Use a mask when working with it)
    There is another type of rigid foam that I think is called Clark foam in US, it is made from PS ( not EPS) and it is stronger than PU foam.
    Best regards,
    Toni
  1. 12345
    By Chuck Thoits in forum Off Topic Discussion
    Last Post: 04-26-2009, 05:23 PM
  2. 12345
    By Chuck Thoits in forum Jigs and Fixtures
    Last Post: 03-05-2009, 11:31 PM
  3. 12345
    By Chuck Thoits in forum Turning Tool Questions and Show & Tell
    Last Post: 02-11-2009, 09:27 AM
  4. 12345
    Last Post: 02-03-2009, 02:05 AM
  5. 12345
    Last Post: 02-03-2009, 12:50 AM
