Results 1 to 10 of 11
Thread: electrical fan ?
    17,475
    electrical fan ?
    if you have a fan that is single speed, and is made for exhausting fumes. if you were to put a reostat on it to slow the speed down is that going to harm the motor? and what type of motor could i do that to safely?
    9,077
    I'm no expert but I believe you are looking for a motor that has brushes like your drill or router, not like your bench grinder.
    Floydada, Tx
    1,941
    need brushes or a dc motor.
    May 2008
    SouthWest GA
    88
    No expert but you need to know the amperage/votage of the fan motor and find a fan control for that amperage and voltage. Maybe more inline with a whole house fan control but hard to tell until you know the amp/voltage.
    Hopes this helps.
    Mark
    May 2008
    SouthWest GA
    88
    Larry, found this web site that may help in explaining about fan motor controls.
    http://www.fancollectors.org/info/speed.htm
    Mark
    May 2008
    SouthWest GA
    88
    Larry, one more site that may help.
    http://forums.mikeholt.com/archive/i...p/t-87376.html
    Mark
    17,475
    clarification!!
    ok i have been told by enuff folk that slowing a fand own with reostate isnt a good idea with what i am using so now the next question... this is going in a finish room which already has pressured air coming in room size is
    12 x 16 x10ft high.. how many cfms should i have in the fan? the presureized air is coming from a furnace fan. dont know the cfm of it???
    May 2008
    SouthWest GA
    88
    Larry, From looking at this web site http://www.wikihow.com/Use-a-Whole-House-Fan
    I would say you would need at least a exhaust fan with 2500 to 3000 cfm.
    But again I am no expert, heck I had to look up hoe to spell "cfm".
    You may want to go to a local HVAC shop and ask them to calculate the size exhaust fan you would need.
    Mark
    Larry...
    I don't know whether or not this would work for you...you're finishing room is much larger than mine. I don't have a gzinta fan, just a gzouta. I sealed the room pretty well and framed for a furnace filter in one wall. The fan will pull the door closed the last inch or so, and a thread tied to the filter stands straight out. It does a pretty good job of pulling fresh air through which is filtered for dust control. Eliminates the problem of balancing fan throughput.
    Cheers.
    17,475
    well i was told that!!
    presureizing the room was the best way to push put the bad fumes so that was what i did but i didnt have large enough out hole,,, been just opening the window but that lets out the bad stuff to high.. i want it to go out low where it settles first. i found a fan that is around 2000cfm so i should be in the right direction now thanks for the replies folk
  1. Electrical forum?
    Last Post: 03-11-2013, 01:43 PM
  2. Electrical Cord Fix
    Last Post: 09-01-2012, 04:21 PM
  3. Electrical question
    By Bob Gibson in forum Off Topic Discussion
    Last Post: 08-27-2011, 03:30 PM
  4. Electrical help needed!!!
    By Bill Lantry in forum Off Topic Discussion
    Last Post: 08-14-2011, 03:12 AM
  5. Electrical Done(?)
    By glenn bradley in forum Carpentry and Construction
    Last Post: 10-14-2007, 09:31 PM
