Well, my MM16 came yesterday, a day late. And I had to prod them to not hold off for another day. I don't have a pic of it yet but here is a pic of the jointer. There is more about the jointer on the other temp forum.
Anyway, after I got thfe MM16 uncrated and laboriously got it to stand upright in my garage, I looked it over, stood back and said" What the heck did I buy????" I think I over bought a little on this tool.
It's DEFINATELY 5 or 9 or 12 times what my Griz G0555 was.
I had to put the mobility wheels on it, roll it to the garage door, lean it backward and lay it back on my shoulder, pull it backward into the garage (my garage door is only 72" high), lay it down on a milk crate, put my floor jack under it (with a maple block so I don't scratch it), get the wheels up off the floor and take them off, let it back down off of the floor jack, get it back onto my shoulder (It's now resting on my shoulder and the back of the base), turn it onto the side of the base, and then stand it up.
My garage is 78" high and my saw is 75". It will stand up by tilting it from the side but not by tilting it front to back. However, I can use the mobility kit to move it around just fine with about 3/4" of clearance. When you crank the guides all the way up, the guide rod pokes up through the top of the upper housing. When it's extended all the way up, I have about 3/4" to spare; It fits perfect!!!
I do have a concern though already, When I try to crank the guides up and down, the telescoping blade guard binds up and it gets stuck and I have to try to tweak the guard sections to get it to go up or down. I called Mike (my salesperson) at MiniMax and told him about the problem. Personally, I wasn't filled with confidence with his nonchalant demeanor and explanation, which wasn't very clear to me anyway.
I was disappointed that I would have to fix something on this piece of machinery before I could even set it up but he didn't seem too concerned about that either. I won't be able to spend time setting it up and trying to work out the blade guard problem (why do I have to work out a blade guard problem on a
$2300 piece of equipment again?) until Monday or so. I'll let you know what I find.
Anyone have any similar experience or idea about a fix?
