View Poll Results: what wheel grit to you use for lathe tools?
Voters
32. You may not vote on this poll
  • 40
    0 0%
  • 60
    2 6.25%
  • 80
    14 43.75%
  • 100
    3 9.38%
  • 120
    7 21.88%
  • other
    6 18.75%
Results 1 to 10 of 26
Thread: sharpening wheel grit preference
    11,825
    I am setting up a new Wolverine sharpening jig. As I do this, I find I may have to buy a new grinding wheel. I currently use an 80 grit but am open to change if good reasons for doing so are presented. I am curious as to what the most popular grit is for sharpening lathe tools. An post as to why this is your choice would be welcome also.
    I use the 80 because it was recommended to me by a professional turner. His explanation was that a 60 overheated and removed too much metal too fast. A 100, according to him, didn't remove hardly any metal and, essentially, just polished the cutting edge. But an 80 was "just right".
    lutefisk capitol, USA
    485
    I use the 80 grit white ones with my wolverine.
    I got to say "Other" as I use two, an #80 and a #46.
    I use the #80 about 90% of the time, but the #46 sure comes in handy when I have to reshape a tool or make a tool, it removes a lot more steel a lot faster. I used to have the #120 and #80, but I found, for me, the #120 clogged up really quickly and I did not see much of a difference on sharpness. On my skews, I use the #80 then I have a medium diamond hone (#400 ) and then the honing wheel with the compound on it, to get the skews shaving sharp.
    Works for me!
    Hey Frank, is your grinder a 6" unit?
    Drums, PA
    292
    I finer grit will heat faster than a course grit.
    I use a 60 and a 100 grit wheels.
    11,825
    No. 8"
    Jan 2008
    Stow, OH
    151
    46 & 80. Those are the only two grits that the best wheels come in. You can't get the Norton SG and Norton 3X "K" wheels in other grits.
    Finer grit doesn't remove as much steel, runs hotter than coarse grit wheel.
    According to Doug Thompson who has tried almost every coarse grit wheel, there is nothing comparable to Norton 3X 46 grit K wheel in shaping turning tools.
    I had the Norton 3X 46 grit to replace the OEM coarse wheel from the Woodcraft slow speed grinder. The performance is night and day. It is several folds faster without over heating. I don't have to clean the wheel as frequent as well.
    Gordon
    Gordon, your right the Norton 46 grit K grade will remove a lot of metal in a hurry... the steel gets hot but it doesn't burn. I hit the spindle tools on a 80 grit K grade wheel before they are sent out, IMO this is a good edge.
    Vancouver
    191
    I voted other as I use 80 for my gouges, and 120 for my skew and parting tools
    Inside the Beltway
    2,666
    I voted other too, as I have no idea what grit came pre-equipped on my six inch grinder....
    I assume my setup is substandard, but it's a far sight better than the things I was trying before....
    Bill
  1. Pocket Screw Installation Tool Preference?
    By David Agnew in forum General Woodworking Q&A
    Last Post: 08-04-2015, 08:42 AM
  2. Table Saw Blade Preference? - ***UPDATE***
    By Bill Arnold in forum New Tools
    Last Post: 09-18-2013, 10:16 PM
  3. 6 X 80 Belts, two 60 grit, two 80 grit - SoCal - GONE.
    By glenn bradley in forum Classified Ads
    Last Post: 01-09-2013, 02:40 AM
  4. revisiting sharpening wheel grit debate
    Last Post: 06-18-2009, 08:04 PM
  5. On the "effective" grit of a wheel
    By Kurt Whitley in forum Turning Tool Questions and Show & Tell
    Last Post: 09-15-2008, 02:13 PM
