Results 1 to 10 of 12
Thread: Will the Screw with the Real Name Please Stand
    Bob Wiggins is offline Former Member (by the member's request)
    140 miles west of tulsa
    125
    I bet you guys know the real name of these screws.
    The shank diameter measures about .100" and the head dia. is .225". The screw pictured is 2-1/4" long.
    Anyway, I bought them at a garage sale without a package so I just call them a "finish screw" but I'm sure they have a real name to distinguish them from the common bugle head, deck screw or drywall screw etc.
    I'd sure appreciate a correct name to identify them. Thanks, Bob
    Attached Thumbnails Attached Thumbnails screws - finish  2-1Qtr long 9-7-08.jpg   screws - finish - head 2-1Qtr long 9-7-08.jpg
    Independence, Kentucky
    1,355
    Robertson Trim Head screw.
    Chuck
    5,323
    Quote Originally Posted by Charles Hans View Post
    Chuck
    Yep! Probably a #6 screw size, with a #1 (small) Robertson head.
    here in the sticks we call `em "trim head" screws......
    and jim`s right the ones i buy have a #1 drive.
    9,077
    +1 in agreement. Just used some on a project.
    Westphalia, Michigan
    955
    I think Mcfeely's screws has quite a selection if you need more.
    Rio Rancho, NM
    1,417
    I know them as square-drive screws, McFeely's is only one place that has them--they are becoming quite common, particularly for drywall and decking use.
    Nancy Laird
    dandnspecialties@msn.com
    I call 'em "this stupid Phillips head screwdriver is worthless" screws.
    The phillips head screw was meant to be worthless. It was designed for unskilled workers of world war II building bombers and other planes. The phillips head would cam out long before the screw broke. Before that they had a lot of problems with over tightening.
    The square head drive was one of the first developed, but over taken by the slotted headed and then the phillipshead. They are just now coming BACK into vogue,but they are nothing new.
    If you want to see some odd-ball screw heads, look on the backs of street signs. One way screw heads.
    Sep 2007
    Central (upstate) NY
    1,457
    The local Borgs carry them in 1 5/8" length. The people working there will likely not be able to find them though, especially not if you call them "finishing screws". However, that one box out of all the other boxes of drywall and other screws will make itself seen just after you've given up and decide to walk out without them after spending a half hour not seeing it.
    DAMHIKT...
  1. first real wood real cribbage board on cnc
    By Dan Noren in forum Computer-Aided Equipment Project Showcase
    Last Post: 07-12-2015, 04:52 PM
  2. DIY Screw Drivers
    Last Post: 04-27-2015, 03:47 PM
  3. What screw to use?
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 10-05-2010, 03:00 AM
  4. type of screw to use?
    By Ralph Tafoya in forum General Woodturning Q&A
    Last Post: 02-16-2009, 03:34 AM
  5. Oneway screw
    By gary doby in forum Turning Tool Questions and Show & Tell
    Last Post: 01-21-2008, 02:51 AM
