Page 1 of 5 12345 LastLast
Results 1 to 10 of 50
Thread: Getting rid of the "Pink Room"
    2,784
    Well, Rennie's renovations are winding down and really looking great. Mine are just starting, and will go a lot slower than his since I don't have any vacation time to use.
    A little background: We bought this house a little over 4 years ago. Went from a 1320 sq ft house to one that is 2520, plus a detached building for a shop. You've probably seen my thread on the shop rehab...this one won't be near as long. This house has carpet in every room except the kitchen, the half bath, and the utility room. They have linoleum. Even the 2 full baths have carpet. All the carpet is blue, except this one room off the entry...it's pink. In fact, the walls are pink, the trim is pink and the crown molding is pink. Thus we have always called it the "Pink Room". I thought originally I would get this room to rebuild my HO train setup. I had planned to wall in the double door width opening to the entry, put in some stained glass that was back lit, put a bench under that for the students parents to be able to sit and wait, and reopen the closed in door to the hallway by the other 2 bedrooms, as that is how the house was originally built. It served as a storage room until recently when LOML needed another computer up for her music students. Now the push is on to make it less pink.
    I started last weekend with scraping the popcorn ceiling from the Pink Room and the entry. With other activities going on, that was about all the time I had available. This weekend was no exception. So after my shopping yesterday AM in the rain, and finishing up at the rescue dog event my wife was at, I got home in time to make about 8 trips up into the attic to get an electrical box back in the center of the room for a ceiling fan and light. The only light in this room was the one that was in the area that was designated for the closet, until they tore the walls down. Makes for a little alcove that we will put a futon in for parents to be a little more comfortable while the kid's lessons are going on. Can double for a bed when company comes.
    I found a wire (10-3 + gnd) coming up out of the wall area that should be for the original ceiling light. It was the right length. No power on it. So I hoped I could find it in the wall by the original door and re-use it and make a 3 way set up in case someday it's made back into a bedroom. I added 2 more wires that go over to the wall by the opening to the foyer to be the other 3-way switch, and for the ceiling fan control. I measured about where I wanted to put the box by the original door, marked it with the box I was going to use. Used a drill to poke a hole and run to the stud so I could be close to it. My markings were right on! I use my drywall saw blade to cut out the sheetrock, and imagine my surprise when the sheetrock falls away and I find this: Click image for larger version.
ID:	23868 !!! I couldn't believe it. What I didn't expect to find in the wall was power. There are 3 sets of wire coming into the box in addition to the 1 set I found in the attic. I know one goes to the switch for the closet light, and another probably goes down to the outlet below. But I'm not sure where the power in comes from. There is a linnen closet the same depth as the closet on the other side of the wall, then the bathroom on the other side of it (between the original 2 bedrooms). Seems like an odd way to run the infeed, but it works for me! So I have power for the 3 way light switch. I will have to run power for the ceiling fan from a junction box about 6' from the ceiling fan box I installed. Odd that the electrical box wasn't still up in the attic.
    OK, 2 more pictures to show the room, and I'm out of here. The first one is taken from the entry way showing the beautiful wall paper . It also shows the wall I found the hidden electrical box in. Click image for larger version.
ID:	23870 And then a better picture of the pinkness of the paint to show that I'm not making this up. Click image for larger version.
ID:	23869 It's a little too dark to do justice for the carpet, though.
    I did get one coat of mud on the screw holes, some sanding done, and the ceiling wiped down. Now to get on with getting the rest of the mud on and sanded so that I can start the paint and texturing process. Thanks for looking in. Hope this will be entertaining! Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    30,014
    Now Jim, why in the world would you want to cover that awesome pink color? The mere fact that it can cause migraines just looking at it shouldn't be a deciding factor.
    This should be a fun one to watch. Keep us posted.
    Goodness, that is really PINK, make me wonder what, or who lived there before
    My mom got my dad to pain the living room in their house a few years back, she sent me pictures of it............ WOW is it "Cranberry"
    When we went to visit over this last summer, I saw the room for the first time, in person, my mom asked me what I thought, I stood there for a moment and said "Well......... one day................ that is going to take AT LEAST two coats of GOOD paint to cover up........."
    My dad laughed so hard, I thought he was going to hurt himself
    Good luck with this, we will be watching!
    London, Ontario
    3,383
    No way. if it is dark cranberry then you really should prime it first to save the headaches. So that's THREE coats.
    Constantine, MI
    7,890
    Yes, the room is pink. In fact, every time I start to feel bad about my pink fireplace I think I'll come to this thread to remind myself that I don't have it so bad after all.
    Now, I thought I had some excitement with out of square framing and bumpy floors, but poking a drill bit through a ceiling and into a live junction box? That's exciting!
    Good luck! Between you and Stu I'll be getting my 'renovation fix' vicariously for at least the next month or so!
    www.wrworkshop.com
    2,784
    Yeah, lucky I didn't go in much past the thickness of the drywall!
    Oh, and our fireplace is baby/sky blue. If they had left it the natural brick color it would have been great. I've contemplated trying to strip it, but I know I could never get all the blue out of the cracks and crevaces. The bad thing, this fireplace is so massive already, I don't think I can add anything to it, so we will probably have to faux paint it and try to simulate brick. But that's a project for another year. Jim.
    Exclusively Irish!
    Monroe, MI
    470
    We had the pink room in our first house. Luckily a year and a half later we had our daughter. I told my wife it it wasn't a girl I was heading straight home to start renovations.
    Ode to MR BUBBLE!
    Wes
    2,784
    Quote Originally Posted by Matt Meiser View Post
    Lucky you!!
    Well, this is going slower than I thought it would. Multiple pre-engagements the last 2 weekends kept the start of the work to a minimum. Then this week, I had my colonoscopy scheduled. I worked a little yesterday after the procedure, and I've sanded the ceiling, and got another coat of mud on the truly offensive areas, but I'm telling you, I haven't been very comfortable doing it. Procedure was fine. But all the cleansing has left me...shall we say...swollen and sore.
    I hope I can sand one more time tomorrow, then get the final coat of mud on. If I can get one more sanding done after that, then I'll be ready to texture. But someone is supposed to be working on the wall paper in the hall, and she hasn't touched it yet. Guess I know what that means.
    I'd take a picture, but you wouldn't be able to see anything in it, so I won't bother.
    Anyone know where I can buy one of those little inflatable donuts???? Jim.
    Exclusively Irish!
    2,784
    Well, I almost decided to blow the room up this morning. The closet wall that was taken out and badly patched was worse than I thought. I hadn't gone across it with my 12" knife yet. I had repatched both seams with fiberglass tape and mudded them in already. Had to sand through one of them. Sanded down the ridge with my ROS and vacuum hook up. Still no where close. If I held the 12" knife where it was flush on one side then across the ridge, it was showing a 1/4"+ gap at the other end! I feathered out about 16 to 18" on either side of the ridge. I still have some final filling and sanding to do, and may feather out a little further, but I think this will look ok. I hope it does, or I'll be back asking where a DIYer can buy a few sticks of dynamite!
    Hopefully these pictures will come out ok. The first 2 are of the offending site, one from each angle, and one with and one without the light. Click image for larger version.
ID:	24045Click image for larger version.
ID:	24046 Yes, I have a big hole to fill there. It will be done in several layers, with fiberglass mesh tape in each for strength.
    This last one shows the other side of the ceiling. Down to being sanded and it should be good to go. Click image for larger version.
    Hope you are having a great weekend! Jim.
    Exclusively Irish!
  1. SIMPLE JIG! turns a "bowl" on "tablesaw"!
    By steve kelly in forum Carving
    Last Post: 11-01-2015, 03:21 PM
  2. "Crime Doesn't Pay" or "No Good Deed Goes Unpunished" ?
    Last Post: 11-21-2013, 05:57 PM
  3. Thompson "V" Versus "U" Bowl Gouges
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 06-25-2013, 01:46 AM
  4. I just love "From Me" -- "To Me" Christmas presents!
    By Mack Cameron in forum Turning Tool Questions and Show & Tell
    Last Post: 01-29-2010, 12:06 AM
  5. "Cording" the "Cordless" drill
    Last Post: 10-01-2008, 03:52 AM
