Results 1 to 5 of 5
Thread: Wood tear out question with sharp tools ?
    Palm Springs, Ca
    1,169
    When i bought some equipment (bandsaw and tablesaw) at a buss. close out type sale the owner gave me a truck load of wood that was in a scrap pile. I brought it home, cut it up and glued it together to make a turning blank for the fun of it. However there were several problems i ran into with this type of wood.
    with the face plate on it the screws just loosened up and the pc came flying off. To solve the problem i screwed it back on with more screws and used the tail stock to hold the other end......it worked......
    however as i turned it (with sharp tools-Ci1 and sharp gouge) it made large pc's come off of it with very very bad tear outs all over it.
    I think its the wood - very very light weight wood (used in making wood shutters for homes i think he said) ie....a bit heavier than balsa wood is a good comparison. i attached a picture here to see what anyone else thinks.
    Ahhhhhhh well i guess i can use it for other stuff or firewood.....
    30,015
    Dan, it seems to me there are some woods that just don't like to be cut cleanly. Soft punky woods are one of the worst for me, and it sounds like that's what you're dealing with. A lot of times you can get a much cleaner finish on this type of wood with a shearing cut with either a scraper or the flute of a gouge. Bill Grumbine's first bowl-making video has a good example of doing a shearing cut with a gouge.
    Palm Springs, Ca
    1,169
    i tried a shearing cut to and no luck with it either.....the stuff is just way to light
    North West Indiana
    6,098
    Well, if you really like the wood and the eventual design is ingrained in your mind, you could cover it with a layer of thin AC glue. This will harden the outside, as you cut through the layer of glue, add another layer.
    You say you added more screws. How many did you start with and how many did you go to? (I always try to use all of the holes) and bringing up the tailstock was a good move. I do that as I hate having wood bash me in the face or fly by!
    Jon
    11,832
    Yep. What Vaughn said. Time to scrounge some hard-hardwoods.
  1. 3 tear table
    Last Post: 03-05-2011, 03:25 AM
  2. Have you shed a tear lately ?
    Last Post: 06-08-2010, 03:57 PM
  3. Using sharp tools.....OMG
    By Tom Baugues in forum Turning Tool Questions and Show & Tell
    Last Post: 10-17-2009, 08:01 PM
  4. Big tools, big wood, little lathe
    By Barry Richardson in forum Turning Tool Questions and Show & Tell
    Last Post: 04-05-2009, 11:55 AM
  5. end grain tear-out problem
    By Frank Fusco in forum General Woodturning Q&A
    Last Post: 12-08-2006, 05:35 PM
