- Constantine, MI
Given the money and space, for me the SIP's can't be beat for a shop. I look at them every time I go to the local home show and think, "wow, what a great shop this would make!"
take a good look at chris rosenberger's shop in smc shop tours its a ways back but it is what you describe been there myself and seen it first hand,,
I did the same! c'mon larry - give it up!searched high and low and couldn't find it. Did a search on all the threads that Chris started and couldn't find it. Got a link?
AgreedThey're a great system, but wouldn't you need a crane to get the SIPs in place on a roof? Even standing up a 4 X 10 panel for a wall can get nasty if there's any wind. Definitely a two or three person job, no?
The sips buildings I've seen locally only use a ridge beam for the roof. The Sips panels I have looked at can easily span 20'+ @ 4:12 with only the walls and the ridge beam. Makes for a nice wide open space.sip`s are great..........but..........they are not self supporting, the roof must either be trussed or steel purlins. for walls electrical is a bugger unless you don`t mind surface mounted conduit?
bang for the buck with the ability to match the house i`d go with a steel structure, use sips on the roof if you want but fill the wall bays with conventional framing.....by using stud walls you have the same finishing options as a house, by going steel framing (red iron) you can easily span 40` and do what you like inside later....
advice is worth what you paid for it
Surface mounted conduit is fine with me. Also, the ability to hang almost anything from almost anywhere would be a big plus.
Think of it as one big, flat I-Joist.maybe it`s just me but spanning 24+ feet with osb and foam isn`t something i`m comfortable with.....setting sips on trusses or purlins i`d go for.....but i ain`t no engineer
art raises a good point about roofing materials.......might be worth a call to your shingle mfgr. if you like the idea of sips for a roof?
Here is the company near me that sets up an exhibit at the local home show.
Gee Tod. Bummer. (see my sig line)i don`t trust "i" joists either rennie......floors should be framed out of douglas fir or don`t bother.......just how i do things
