Results 1 to 7 of 7
Thread: Grain direction
    5,533
    Grain direction
    I was sorting through my boxes of cut-offs today, and came upon a number of pieces similar to this one:
    8/4 Mahagony pieces... I realize I could turn bottle stoppers or some such, with the grain along the axis of the turning. can those be turned with the grain going opposite the axis?
    Also, I've got a bunch of pieces similar to the one in the background: 10/4 QSWO. That one is probably going to be a bandsaw box, but I've got a fair amount of 3/4 oak pieces. I was thinking of small platters or bowls out of those, or should I just toss them on the burn pile?
    -Ned
    Sacramento, CA
    1,367
    USUALLY, i have large chunks facet off with my normal spindle turning tools. When I use a bowl gouge, though, i have better luck. The geometry of spindle tools seems to get under the grain enough to blow it out.
    Jason Beam
    Sacramento, CA
    Quote Originally Posted by Ned Bulken View Post
    ...Can those be turned with the grain going opposite the axis?
    I think you'll be fine with either orientation. One may be easier than the other, depending on your tools and how the wood cuts, but I've done both.
    ...Also, I've got a bunch of pieces similar to the one in the background: 10/4 QSWO. That one is probably going to be a bandsaw box, but I've got a fair amount of 3/4 oak pieces. I was thinking of small platters or bowls out of those, or should I just toss them on the burn pile?
    If they are 3/4 thick, I'd think you could get small platters out of them. Best way to find out is try one or two. If you don't like it, then go for the BTUs instead.
    5,176
    Burn pile? BURN PILE??? My goodness, Ned. You have a lathe! You need to find a place for shavings!
    11,833
    As Jason said, bowl gouge. I would say that also but bowl gouges are impossible to use.
    Pictures later are mandatory.
    5,533
    Carol,
    that's where I got them... literally from the burn pile at my wife's fire company field days... they cook their bbq chicken on scrap cut offs. At most they're about 6" long by 5 or 6" wide. I'm not out much if I toast them. Cost was right.
    I wish I Had a bowl gouge...
    one of these days...
    -Ned
    Aug 2008
    orlando, FL
    69
    The only luck I have had with short grain ( that's my term for it) is with a skew. Everything else seems to knock chunks out, then again I haven't tried out a bowl gouge on some yet. Maybe tomorrow....
  1. Direction to help my sons on a Homeschooling project
    By John Bonner in forum General Woodworking Q&A
    Last Post: 07-23-2015, 01:37 AM
  2. Plane blade direction
    By Jim Burr in forum Neander Woodworking Q&A
    Last Post: 05-22-2011, 11:53 AM
  3. open grain vs. closed grain hardwoods
    Last Post: 04-09-2011, 02:35 AM
  4. is there an easier way to get textures going in the right direction?
    By Mike Gager in forum Designs, Plans and Sketches
    Last Post: 02-18-2009, 08:37 PM
  5. MP3 Neophyte needs direction
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 01-19-2009, 01:57 AM
