Results 1 to 8 of 8
Thread: Miter Saw Stop Block?
    13,357
    I've got a dewalt 12 inch Miter saw on a Delta collapsable rolling stand.
    What I'm looking for is a way to attach a fence to the saw that will allow me to use a stop block to make repeatable cuts.
    Anybody out there whos come up with a creative way of doing this on a portable stand that would like to share?
    Thanks!
    13,357
    This is the one I have
    Delta Universal Miter Stand
    It appears to not have an adjustable stop block as part of it's make up.
    It does excel at being able to be moved around, so I suspect that feature was excluded to make it more portable.
    I've been thinking about options like a removable top rail, or something that bolts to the face of the saw fence.
    Pa
    186
    It's hard to tell from the picture, but if the roller bracket has
    an "L" iron just below the roller like the Ridgid portable
    stand has. then that is the adjustable stop.
    The roller adjusts high and the end of the board butts up and sets in to
    the "L" iron just below the roller. It doesn't get real close to the blade
    but is a stop never the less.
    Donít have the best tools, don't use the best woods and projects donít always turnout perfeck.
    I just feel the need to work with wood!
    13,357
    Well, Here's what I came up with.
    My solution starts with a 6' long piece of 1" square Aluminum tubing and a thick chunk of maple scrap.
    Using existing holes on the back of the miter saw, I tapped them for 5/16x18tpi and drilled some appropriate holes in the Aluminum tube.
    Using a dado blade, I cut a 1 inch channel in my stop block and drilled and tapped a hole in the back for a knob.
    To reduce the knobs tendency to shift the stop block when tightening it, I put a little rare earth magnet on it.
    I also put a stick on tape measure on the tube to make setting the distance easy and repeatable.
    For cuts that are shorter than 12 inches, I cut a piece of scrap wood exactly 12" long.
    Using another magnet on the stop block and a small screw in the 12" spacer I'm able to set the table up for shorter cuts.
Name:	Stop Rail_sml.jpg
    Nov 2008
    The Couv, Washington
    113
    Hi Brent.
    I have that same stand and have not got around to addressing that problem.
    I need to look at my Makita and see if I can do a similar setup.
    Thanks for sharing.
    We put the "k" in "kwality."
    The above picture is not me!!
    13,357
    It actually works very well.
    It was a quick and easy fix, the only caveat is that you need to make sure to watch out for it when walking around the shop
    I did find plans for a mobile stand with flip up wings from Shop Notes that I'm planning on putting together this winter though...
    I see no reason you couldn't fabricate a "fence" to the Folding stand that will reach out and place a stop block.
    Reciently my mother bought a new Patio home while under construction, the finisher (who was not there when I saw his set up) had left his saw stand in the garage over the weekend..
    I couldn't help but take a couple of pictures, wish I had taken more...
    As you can see, the miter saw (later I saw it was a Compound Sliding Miter Saw) affixed to the center of his stand, and the stand supported the long trim pieces, With such a feature you could assemble a sliding stop block, Just need some thought.
    Anyway, here is another I dea from an old Finishing Carpenter, I believe he said he was 76 years old at the time.
    13,357
    Now that's a very clever stand
    Also a nice way to make some take down saw horses...
  1. Miter saw stop
    Last Post: 03-01-2015, 07:07 PM
  2. Sliding Stop Block, No Trapped Cutoffs
    Last Post: 10-09-2011, 02:59 PM
  3. Incra Miter Gauge - Shop Made Stop
    Last Post: 07-14-2010, 01:08 PM
  4. CMS Stop Block & Extend-o-fence
    Last Post: 07-10-2007, 09:03 PM
  5. Biesemeyer Miter Stop & Fence System
    By Jeff Weight in forum Old Ads
    Last Post: 02-26-2007, 03:41 PM
