Results 1 to 7 of 7
Thread: Tenon attachment ?
    Palm Springs, Ca
    1,169
    Tenon attachment ?
    Ive have read about and seen video on turners that attach scrap tenon to there work, turn the bowl and trim off the tenon but im not having any sucess at doing it.
    Green wood - i have used cyno glue, titebond III, gorilla glue, and a glue gun to attached the tenon (used 2x4 and cut out 2" circles) with the glue and clamp, let dry for a day and they come right off at the joint when start to rough turn. Not sure where im going wrong
    One article i read the guy uses scrap plywood and attaches his tenon tha way. Another uses scrap wood like i did and they seem to hold like concrete.
    Any thoughts on what i may be doing wrong ? is it the green wood because of moisture content ? or the 2x4 plugs im making ?
    In one sense it is not a big deal because i use a supernova II with spigot chuck that really grips well on a small turned tenon but i like being able to understand and use different techniques
    Hmm...is the surface on the blank pretty flat? If it's uneven, then it'd be hard to get a good glue joint. If it is even, I think I'd try a harder wood for the tenon. (Is the glue joint failing, or are there traces of the pine 2 x 4 still stuck onto the blank?)
    Drums, PA
    292
    I use glue blocks all the time.
    Both mating surfaces MUST BE PERFECTLY FLAT.
    I've used dry blocks onto green bowl blanks with success.
    I've used face grain block to end grain blanks on the boxes I turn with success.
    I use thick CA glue.
    BTW - I only use hard wood, not to sure how pine would work
    Tellico Plains, Tennessee
    4,353
    I use glue block also, and have used pine on occasion, but only for light turnings.. if you put a lot of stress on the pine, it will break and separate from your piece. For heavier turnings, you will need hardwood. I prefer to use a wood glue like Titebond for my glue blocks, but CA will work.
    Chuck
    Tellico Plains, TN
    Westphalia, Michigan
    955
    I haven't done this yet, but I would suspect that the water based glues would take longer to set up when glued to green wood because of the moisture in the wood.
    Palm Springs, Ca
    1,169
    Thanks for the information:
    the joint fails where it was glued and sometimes it will leave small amounts of the pine from the 2x4.
    I have some 2x2 walnut laying around so ill make a new tennon and try using that ....you may be right its just not strong enough
    Gluing time - i have put them on overnight and even for a couple days and still ended up with the same problem.
    Im thinking that if you have used the method and its working then it has to be the wood (pine) im using so ill try the switch - one video i saw showed the guy using plywood to make tenons so i thought the 2x4 idea of 2" tenons would work........but it hasnt.....thanks and ill let you know
    Drums, PA
    292
    I don't think plywood is good to use either, especially construction grade ply.
  1. Attachment
    By Jim C Bradley in forum Site Questions and Test Posts
    Last Post: 01-04-2014, 07:30 PM
  2. Tenon problem ??
    Last Post: 01-03-2011, 02:09 PM
  3. Bandsaw Tenon Jig
    By Dave Richards in forum Jigs and Fixtures
    Last Post: 10-24-2010, 09:46 PM
  4. Tenon Jig
    By Steve Southwood in forum Jigs and Fixtures
    Last Post: 12-31-2009, 02:59 AM
  5. Tenon vs. Loose Tenon
    Last Post: 04-13-2007, 11:18 PM
