Results 1 to 6 of 6
Thread: spray gun question???
    17,472
    ok i have been at this sprayun thing fer abit but havnt ran into this before..i have some lacquer that i have been told to spray, as is outa the can by the manufacture and others in the know,, what am i doing wrong??/ i get spatter effect rather than a smooth wet coat.. hvlp conversion gun.. do i need to increase the flow of the material because its thicker or increase the fan? the air pressure is maxed already...in the past i have used regular lacq and had it thinned or right out of the can it was thinner than this stuff is.. so my gun was set for that setup and i just tweaked it to get it tuned in. this time i am way out in left field.. the gun is a PC PSH1 and i think the needle is 1.4...in my small pea head it would make sense to make more fluid flow by opening the needle valve more to let it out.. kinda like puttin jam threw or milk// help!!! this is pre cat lacquer.. thansk fer the advice
    Southern Louisiana
    947
    larry, i am definitely not an expert, but if it is thicker, wouldn't you possibly need a bigger tip for the gun. or is it not thick enough to need that.
    me and my brother had this problem this past weekend and the only thing that would fix it (since we couldn't try a different tip) was to hold the gun closer and move it slower. not sure if that would help your situation though.
    it was an hvlp also, a turbine powered system. not expensive by any means
    worth a shot i guess, if you have something to test on
    chris
    4,552
    Larry close he fluid valve down then get you a piece cardboard to spray at and adjust the fluid open till you get the spray you want also the atomization pressure should be about 30 psi. You can get to much pressure with a HVLP.
    Also if it seems to thick you can thin it with lacquer thinner I did it all the time even when they said not too. I shot a lot of Prue-cad that was thinned.
    But note that you can get it to thin and have a whole different problem.
    Jay
    thin it larry.
    Rio Rancho, NM
    1,417
    thin it larry.
    Yup. I don't know of any lacquer that's ready to spray right out of the can.
    Nancy Laird
    dandnspecialties@msn.com
    17,472
    Exclamation well i tried it agin
    and after playun with the gun and tryun what was told of me, i got another heavy coat on sorta, it had a couple dry streaks when i got done.. so i went for ride and came back lightly touch sanded it to get any bumps off and thinned the last shot to aprox 20% or maybe less,, anyway that let me get it on wet like i used to.. still wouldnt want this to be in any show place. its just a eatin spot and will have to do,,, wish i had tod in my back pocket to watch & tell me what the heck i was doin wrong.. i will say this tho its tougher stuff than normal lacquer.. the sanding floated across without gettin much hold like the other does.. so thanks for the help and replies.. the tip appears to be 1.5 rather than a 1.4 i think.
    i hope next time is better, tod if you get in the neighbor hood in the next 5 months stop in...
  1. Spray Finish Setup - Question
    Last Post: 08-01-2011, 07:16 AM
  2. Spray Finish Question - Regulator Filter
    Last Post: 07-21-2011, 12:59 PM
  3. Insulation question - rigid & spray foam hybrid
    By Matt Ducar in forum Carpentry and Construction
    Last Post: 02-27-2011, 05:55 PM
  4. Spray Gun Question....Mini vs. Full-Sized
    By Vaughn McMillan in forum Finishing School
    Last Post: 10-24-2008, 08:40 PM
  5. Small Gravity Feed Spray Gun Question.........
    By Stuart Ablett in forum Finishing School
    Last Post: 12-02-2007, 04:39 AM
