Results 1 to 5 of 5
Thread: Second Bowl in progress
    Sep 2008
    Tacoma, WA
    84
    Here is my second bowl in progress.
    I work at Weyerhaeuser's R&D Tech Center as a materials test technician. We manufacture a shear wall for homes out of Timberstrand. Timberstrand is similar to OSB, but it uses a different pressing method and produces a much heavier and evenly dense piece. The walls are 3.5" thick and the last ones we tested were 24" wide and 12' tall.
    So I cut some blanks thinking it might make an interesting turning.
    If nothing else I can say that the tested material doesn't just get thrown away.
    I have finished the outer shape, I just have to turn it around. I have to stay ontop of the sharpening since there is so much resin in the Timberstrand it dulls the edge quickly.
    By the way, that is a 1950 vintage shopsmith my grandfather bought new from Montgomery Wards. I did some machine work to remove quill and spline drive setup. I found it chattered too much. So I machined a new shaft with MT2 and 1"x8tpi.
    It works wonderfully, I just need a bigger motor now.
    Keith
    30,014
    That should look cool when it's finished. I've seen a few pieces done with various types of engineered lumber...I've not seen Timberstrand, though. I'll be looking forward to seeing the finished piece.
    Los Angeles, CA
    2,668
    I will be watching the progress on that with great interest.
    Drums, PA
    292
    Quote Originally Posted by Keith Palmer View Post
    Goodland, Kansas
    4,834
    Can't wait to see it finished. Looking good.
    Bernie W.
  1. Progress!
    By Carol Reed in forum New Systems and Builds
    Last Post: 05-28-2016, 03:19 PM
  2. Wavy Ash NE Bowl in Progress
    Last Post: 05-24-2010, 11:52 AM
  3. in progress natural edge bowl
    Last Post: 03-05-2010, 12:12 AM
  4. Curly Maple Bowl - In Progress
    By Matt Hutchinson in forum Lathe Project Showcase
    Last Post: 03-10-2009, 12:41 AM
  5. Progress
    By Tyler Howell in forum Shop Tours
    Last Post: 03-19-2007, 10:26 PM
