Results 1 to 5 of 5
Thread: Delta/Cresent jointer
    Hedgesville,WV
    158
    hey folks, I have a question... I picked up a long bed 8 incher from a school system in Pa, with cast iron base cabinet. after taking it apart to retigten the screws that worked loose during transport, and to replace some that were missing, I reassmbled it yesterday to find it isn't fitting square oin the base. it can only go onto the base 1 way( 2 bolt slots on 1 end--1 on the other).also the casting seems to not allow the body to lay flat on the base..it's teetering on the bolt slot. didn't notice it while dis-assembling, cuz after the 4 hr trip, everything had worked loose anyway. does anyone know if these bodies laid flat on the cast iron base?
    I don't know, but since the tool bolts on, I will guess yes, a consistent attachment was the design. Cast iron is softer than your think.
    Wild guess number 1 - Put a shim under one corner or another. The effect is similar to aligning side-by-side refrigerator doors by raising or lowering a corner of the cabinet.
    Sep 2007
    St. Louis, MO
    583
    Yep - shimming is the tried and true way to adjust the wedge bed jointers. Hope you have someone to help
    paulh
    Hedgesville,WV
    158
    Quote Originally Posted by Paul Hubbman View Post
    paulh
    Thank You fellows..I shimmed it with washers.. worked great!!
    "Treat everyone equally,keep your word, and overlook peoples' mistakes...you'll make plenty yourself "..... spoken to me by a much wiser man than I.
    Jul 2007
    DSM, IA
    5,719
    James, congrats on the new old iron, but......you know what they say,
    "NO PICS DIDN'T HAPPEN!"
    My Website
  1. Delta 6" jointer
    By paul newton in forum Old Ads
    Last Post: 02-10-2011, 11:42 PM
  2. Delta DJ-20 Jointer
    By Dan Gonzales in forum New Tools
    Last Post: 04-18-2009, 08:00 PM
  3. Invicta Delta Jointer DJ-15
    By Ted Jay in forum Hot Deals
    Last Post: 07-23-2008, 10:53 PM
  4. Delta DJ-30 12" Jointer
    By Stuart Ablett in forum Hot Deals
    Last Post: 05-07-2008, 04:30 AM
  5. Delta model 10 RAS and Jet 6CS jointer
    By Randy Davis in forum New Tools
    Last Post: 04-17-2007, 03:14 PM
