Results 1 to 3 of 3
Thread: Kreg Bandsaw Table and Fence ?
    Palm Springs, Ca
    1,169
    After my last post on suggestions for a bandsaw fence i saw the ones made by Kreg on the Rockler.com site ($149.00).
    It would seem that if i bought the table and fence that i could put them on either the Central machine 14" or the Davis-Wells (table measures 25 3/4 square). The table is 24x24 x 1 1/8, 25 1/4 adjustable fence.
    There are bolt holes on the Central machines edge but nothing on the Davis-Wells.
    Both would handle the 10 1/2" from center of blade to throat of the saw requirement........
    It looks like i could place the table and fence as one unit from one saw to the other as needed.
    Comes with circle cutting attachment for cutting blanks............
    Question: I do not currently own one but i was wondering if i could move the table and fence unit Rockler is selling as one unit from saw to saw ?
    Question: The Resaw attachment fence is sold seperatly in 4 1/2" or 7"....not sure i need it but could someone elaborate on the uses of this ? and which size is best (only $2.00 in price......$18.00 and $20.00)
    Question: Regarding the Central Machine 14" - Rocker website is selling Cool Blocks and Ceramic Blocks but it does not say if they will work on the Central Machine........anybody bought them or know ?
    Jan 2008
    Austin TX
    405
    Dan,
    Question #2: The resaw attachment is not a necessity. You could clamp a tall board to the fence and ultimately do the same thing their attachment does. This just provides a taller reference to perpendicular so the wood being re-sawed will be cut evenly, top to bottom.
    Not sure about the answers to #1 or #3.
    Lee Laird
    Austin TX
    Alexandria, Virginia
    1,071
    I bought the table from Rockler and am pleased. You can move it between tables, but it would be optimized for one or the other. Because I have a smaller Craftsman bandsaw I mounted mine with the underside hold downs. It has two ways of attaching. As stated above or using a (supplied) bar that fits in your miter gage slot and then screws into the table from below.
    As my saw is smaller, it barely met the 10 1/2" requirement from center of blade to throat of the saw. I loosened the blade and installed the table.
  1. KREG BANDSAW FENCE ON LAGUNA 14-12 SAW?
    By Ron Latour in forum General Woodworking Q&A
    Last Post: 08-21-2015, 12:31 PM
  2. High/low bandsaw fence
    By Roger Tulk in forum Jigs and Fixtures
    Last Post: 04-17-2012, 12:33 PM
  3. Replies: 4
    Last Post: 07-08-2011, 04:34 AM
  4. SOLD: TABLE SAW FENCE - SHOP FOX CLASSIC (fence only)
    By scott spencer in forum Old Ads
    Last Post: 05-12-2009, 05:18 PM
  5. Bandsaw Fence ?
    Last Post: 09-29-2008, 02:26 AM
