Results 1 to 10 of 15
Thread: First pens
    5,533
    First pens
    Well,
    Don Orr was gracious enough to show me all of the fiddly little details of pen turning... how to drill out the blank, glue in the tubes etc... and as a result I have two nice pens to show for it:
    Mahagony with 'gold' slimline kit from woodcraft.
    This one turned out quite nicely, so I'm donating it for a benefit auction this weekend.
    And my third pen (2nd one is still in progress)
    spalted maple
    had a little bit of tear-out along one of the bug-trails, which I still need to fix, this one is staying with me u ntil I fix it, then I might give it away as a gift.
    all in all, very fun, if a bit 'fussy' but easy to do and I look forward to doing more in the near future.
    -Ned
    11,831
    Great start. Watch out for the addiction.
    13,360
    Ditto what frank said.
    Soon, you will have a box full of kits, extra tubes, your fingers will be covered in cyanoacrylate glue.
    You'll be constantly looking for ways of creating new and interesting blanks, perhaps even venturing into casting your own acrylic blanks or stabilizing punky wood with resin, vacuum pumps, and pressure tanks!
    Watch out!
    Bucks County PA
    149
    Fixing bug holes
    Ned,
    The best tip I ever heard for fixing bug holes was to use charcoal and coffee grinds. Charcoal from a charcoal pen. Use sandpaper to make fine dust and then dump it in the holes. Spray with accelerant and then just touch it with thin CA glue.
    Use the coffee to fill big voids and fill in the gaps with charcoal. I used this technique on some mesquite to make the voids look like they were filled with bark. This also works well on ambrosia maple because it doesn't hide the beetle holes as much as show them off.
    See ya around,
    Dominic
    Goodland, Kansas
    4,834
    Great looking pens Ned. Well done. Bugs holes what Dominic said.
    Bernie W.
    30,015
    Good start, Ned. They both look like they came out nicely.
    I second/third/whatever the suggestion to try charcoal and CA. I use it fairly often. I just grind some charcoal up with a mortar and pestle and do about as Dom suggested. You can also do the same with instant coffee crystals if you want more of a brown color. (I use decaf, since I believe all turnings should be caffeine-free. Turners, on the other hand, need all the caffeine they can get.)
    Los Angeles, CA
    2,668
    That is a good start, Ned. Both pens turned out great.
    13,443
    Nice work Ned, they turned out very nice.
    To a small child, the perfect granddad is unafraid of big dogs and fierce storms but absolutely terrified of the word boo. Robert Brault
    Charlotte, NC
    1,487
    Nice job on the pens Ned!
    Never take life seriously. Nobody gets out alive anyway
    Aug 2008
    Reno, Nv
    3,632
    Ned, I regret to inform you that you are probably hooked. Help can be sought on this board.
  1. New Pens
    By Ron Hossack in forum Lathe Project Showcase
    Last Post: 09-09-2011, 12:31 PM
  2. A few Pens
    By Dennis Kranz in forum Lathe Project Showcase
    Last Post: 05-19-2011, 10:01 AM
  3. Just pens
    Last Post: 05-04-2011, 03:11 PM
  4. Two Pens
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 11-11-2009, 01:53 PM
  5. More pens!
    Last Post: 11-05-2008, 10:28 PM
