Results 1 to 9 of 9
Thread: I need help with the next tool purchase
    Herndon VA
    180
    I have a good delimma, I can't decide on my next LN tool. Here are my varied choices:
    LN #7 - I have an older Stanley the mouth is not adjustable and tends to tearout so I'd like to replace that.
    Small or Med Scraper plane.
    LN #5 - Again I have an older Stanley that works ok but I like the heft of the LN and the adjustable frog.
    Pretty much all of my work is medium sized furniture pieces (tables, book shelves etc.)
    I have the 4 1/2 that I love for smoothing, the 60 1/2 R for edge work, and the LA Jack with 2 blades.
    So what planes do you guys get the most use out of?
    4,992
    mike the two planes i keep in my top bench drawer are a low angle block and a rabbiting plane......next used for me is a 4-1/2 then an 8......tod
    Herndon VA
    180
    Tod - For the Rabbet plane are you refering to 60 1/2R or the smaller rabbet planes that trim the sides of the dados?
    4,992
    mike, the one i find myself using more than any others i own is an old stanley 93.....if i need bigger i use a record 073.....the ol` 140 i have actually gets very little use........i don`t own any of the l/n planes yet.....i`m kinda fond of the antiques....tod
    Herndon VA
    180
    Thanks. I have the LN version - large shoulder plane. I use it a lot as well but mostly for tenon work. I'm very fond of the LN tools.
    4,992
    mike, they make very nice tools! i`ve only driven one of the #4`s in bronze and it was sweet! are you surfacing by hand? if so i`d grab either a 7 or an 8.....i like the extra width of an 8 myself........if you`re using highly figured stock or doing veneer work a scraper might be in order....let us know what you decide.....tod
    Herndon VA
    180
    I rough joint and thickness plane with a jointer and planer (electron type). then I smooth with the 4 1/2. For table tops etc. I usually need to run the #7 to get all the boards matched up flat. I normally don't use a press to keep them flat during glue ups. I also use my #7 and LA Jack for edge jointing prior to glue ups to get matched edges.
    The Heart of Dixie
    4,265
    OK got to ask this. Are you sure they are not adjustable? I am not that familiar with all the Stanley types but most of the mouth can be tightened up by loosening two screws and moving the whole body forward or backwards.
    Herndon VA
    180
    Jeff - true statement. The frog can slide forward but it appears the the mouth may have been widened at some point in the past 100 years.
    What I have done is moved the frog to the most forward position and there is still 1/16 or more opening.
    Mike
  1. Need GPS purchase help
    By Tom Baugues in forum Off Topic Discussion
    Last Post: 03-15-2011, 08:18 PM
  2. $25 off $75 purchase at Peachtree
    By Rennie Heuer in forum Hot Deals
    Last Post: 01-01-2011, 12:53 AM
  3. Car purchase
    By Paul Gallian in forum Off Topic Discussion
    Last Post: 10-13-2010, 10:29 PM
  4. Where to purchase
    By Bart Leetch in forum Turning Tool Questions and Show & Tell
    Last Post: 10-01-2008, 06:28 PM
  5. Thinking about my next tool purchase.
    By Don Baer in forum New Tools
    Last Post: 02-07-2007, 02:55 AM
