Results 1 to 7 of 7
Thread: Table saw motor v mounting question ?
    Palm Springs, Ca
    1,169
    I posted awhile back about a table saw i bought and it had a 3phase motor on it.....since i have taken it off and thought i would ask a question about it
    Originally a 10" Contractor saw-Delta
    Having alot of trouble finding a motor for it 115/230 so i callled Delta today. I gave them the following information as the 3phase motor was not OEM and it has a upgraded mounting plate on it which
    Plate is 7 1/2 long x 5 1/2 wide with slots in it for mounting the new motor....4 slots, shaft size is 5/8,
    from the back of the motor to the end of shaft is 13", from the ground to middle of the shaft is 3 1/2"
    They told me to replace it with a 115/230, 1 1/2hp motor, capactor start,RPM-3450.....
    Grainger sells them for $343.00 plus shipping
    Surplus Center has them with 1725RPM and sells for $157.00
    Sounds a bit to slow and couldnt find one with the higher rpm on that site.
    Guess im a bit confused on what to do here and thought i would ask you what you think?
    5,321
    Put a bigger pulley on the 1725 rpm motor.
    Try another of the surplus outlets (or Ebay) online. You'll likely get a better price, and may well find a 3450 rpm motor, too.
    If I recall correctly, you'll need a NEMA 56 frame type motor. Try for a TEFC motor if you can, although Delta has always used an open framed one.
    The Heart of Dixie
    4,268
    I just searched and found this at the surplus center.
    WEG motor
    It would be a good one assuming the base will fit.
    Do you have any mechanical friends? Anyone that might have a used motor? There are tons of used motors laying around that can be picked up on the cheap. Of course scrap prices have sent a lot to the recycle centers.
    Run an add on Craigslist, it's free. Might find one that way. Do you have a maintenance man or department where you work? One of those guys may have some squirreled away and be willing to sale one. I would dig around and ask some before I bought a new one. There is to many sitting around on shelves. I probably have something in my shop that work, so I bet you know someone that does too.
    Custom built boats and Kits
    5,321
    The motor that Jeff suggests ought to be near-perfect for your saw.
    Palm Springs, Ca
    1,169
    motor
    Thanks for the link and the information im going to call them and try to make sure of the dimensions and order it i think......thanks Dan
    Villa Park, CA
    1,407
    If it's a 56 frame, I have a 1 HP motor that I'll sell you cheap.
    Dual voltage and reversible - 3450 RPM. PM me if interested.
    Mike
    Ancora imparo
    Floydada, Tx
    1,941
    A good source for that size motor is farm auctions. They sell 1-1/2 hp motors dirt cheap(less then $20).
  1. This question has to do with mounting a lathe
    By Bart Leetch in forum General Woodturning Q&A
    Last Post: 05-27-2012, 05:23 PM
  2. mounting router table top
    By Rex Bloem in forum Jigs and Fixtures
    Last Post: 12-27-2008, 10:46 PM
  3. New Motor Table saw wiring question
    Last Post: 11-22-2008, 02:45 PM
  4. Table Saw Mounting Bracket Question
    Last Post: 09-23-2008, 04:45 AM
  5. Mounting Router in Table
    By Malcolm Webb in forum General Woodworking Q&A
    Last Post: 11-05-2007, 07:11 AM
