Results 1 to 10 of 18
Thread: SCMI T130 Class shaper
    Oct 2007
    Pacific Northwest
    59
    Well it's not a Martin, but I am in the process of installing the next best thing. I got it to consolidate several dedicated shapers into a single station for my cab door production. I figure that if I am going to survive the downturn in the housing market, I need to invest in equipment that will let me do more with less. This is the most basic Class shaper that SCM offers. They also make a version with CNC control of everything.
    It is fun to do a little show and tell, so here goes:
    The control panel has a reversing switch with indicator light of clockwise rotation, the motor on/off, a speed controller and display for the inverter drive (this shaper can run all the way down to 1000 rpm for sanding), a spindle release switch, and one of 3 emergency stops.
    There is a mechanical digital readout for spindle height adjustment.
    I currently have 2 other heavy duty SCMI shapers and 2 lighter Powermatics that will be replaced by this machine. It has several key features that make this possible. The fence has two wheel adjusters with digital indicators. The left moves the whole fence forwards and backwards, the right moves the infeed side only. I got lucky in that SCM was running a clearance on their aluminum fence plates with bar inserts that can easily be placed across the opening for things like panel and door edges to travel along and never leave a support. Another quick changeover feature is a section table instead of table inserts. You crank the table in and out and the phenolic insert runs up tight to the cutter for good support. The entire fence swings away on a pivot and indexes back in place with a locking pin.
    The spindles are set up with ISO 40 tapers, like some CNC routers. There is a pneumatic system that clamps and unclamps the entire spindle in seconds. The idea is to mount cutters to various spindles and swap the entire assembly rather than mount and unmount from a fixed spindle. Less wear on the spindle and cutter bore, and much faster.
    The spindles are stored on a cart along with any other tools you need.
    The spindle assembly is very robust, and the precision bearings are widely spaced. The assembly that slides up and down inside the cast column is about 20 inches long and close to 5" in diameter. The motor is roughly 7.5 HP.
    The inverter has a big honkin' heat sink around the back, and the electric panel is a bit daunting!
    Hopefully, we'll be making shavings with this next week!
    That's a wood-eating machine. Thanks for the tour. We weekend warriors don't get much of a chance to see that kind of equipment.
    Odessa, Tx
    1,813
    WOW!!!!!!!!
    very nice JR! i`m jealous.
    11,833
    Hearing that from Tod is sumptin'
    His own big shaper is an "Oh My Gosh unreal huge monster."
    John, the machine is impressive.
    And, you are to be congratulated. You stepped up at a time when others might back down. That is the real American spirit and an example of free enterprise at it's best. Congratulations.
    new york city burbs
    10,188
    wow, big complicated piece of equipment.
    must turn out some impressive work. Love to see some after shots if you ever have the time to post.
    Oct 2007
    Pacific Northwest
    59
    Entrepreneur = risk taker.
    I forgot - here is a video that helped sell me on this machine. Even better than pictures:
    http://video.google.com/videoplay?do...69548178557374
    Bellingham
    2,449
    John, I agree with what Vaughn said. I appreciate the chance to see the commercial side. I would have recommended that Larry Merlau (during his visit to the Pacific NW) check out your operation, if I knew you were over there in Ferndale. Hopefully by next spring we will be starting to climb out of this economic downturn. I know a lot of people are hurting in the housing industry. Hang in there!
    11,833
    Quote Originally Posted by John Rutter View Post
    Definitely impressive. Somebody did some good thinking with that. It may be a rare example of users actually having input into the engineering design.
    Los Angeles, CA
    2,668
    Looks impressive. Thanks for the photos.
    I don't know what this machine is capable of but I know for sure that it is beyond my capabilities.
  1. When Insults Had Class
    Last Post: 02-27-2010, 09:18 PM
  2. BYU is a class act!
    By Ron Jones in forum Off Topic Discussion
    Last Post: 02-20-2010, 04:22 AM
  3. Interesting SCMI edge sander
    By John Rutter in forum New Tools
    Last Post: 10-13-2008, 03:45 AM
  4. Taking a Turning Class - Took the Class
    By Sean Wright in forum General Woodturning Q&A
    Last Post: 02-05-2008, 12:40 PM
  5. Question about SCMI sander HP
    By Mark Riegsecker in forum General Woodworking Q&A
    Last Post: 07-23-2007, 10:29 AM
