Results 1 to 7 of 7
Thread: G&G Square Holes
    G&G Square Holes
    There are a lot of pegs in the night stands I'm working on. I had to stop and touch up the motise chisel so I took a few shots.
    A couple cones and a diamond plate touch up the chisel in just a few moments:
    Whack this thing to mark your territory:
    Clean out with a 1/4" chisel to about 1/4" deep:
    1/4" dowel goes through the tenon. 5/16" ebony plug goes in the square hole.
    5,317
    Yeah, works pretty neat, huh?
    I have an old TaiChi 3/8" square chisel that I keep for just that purpose. The drill bit for it broke a long time ago, and just kept the chisel. That way, I don't batter up a 'good' mortising set when setting those square plugs.
    Mortising
    Hey Jim,
    When I make my mortises I take a very sharp knife or chisel and cut around the area where the hole is going to be. I never thought of using a mortising chisel like this. Looks like this method would work better. What do you think? Thanks, Joe
    5,317
    Quote Originally Posted by Joseph J. Ice View Post
    Hey Jim,
    I've done it 'your way' many times, and it certainly works - it's also most likely the way that G&G did it originally, too.
    The square chisel kinda takes the guesswork out of the process, though. It ensures that the mortise will be square, and not a parallelogram.
    Even after tapping out the form with the square chisel, you still need a 'regular' mortising chisel to finish the job. The square chisel is really just a layout tool.
    Quite correct. It is a cheap-o. A $10 Grizzly if I remember right. I just need all the help I can get . The pegs are still done oversize with a taper so really any irregularites get dealt with through tapping them in. This just helps me keep from having them twist CW or CCW whilst tapping away .
    Square peg
    Thanks for the help guys, I just never looked at it like that, sounds good, Thanks again for the help, Joe
    Constantine, MI
    7,887
    This is the way I've done it as well - works great!
    www.wrworkshop.com
  1. MDF and dog holes?
    By Ken Cook in forum General Woodworking Q&A
    Last Post: 12-05-2014, 09:26 PM
  2. here's a video for you greene and greene guys cutting square holes
    By John Daugherty in forum General Woodworking Q&A
    Last Post: 11-13-2011, 01:14 PM
  3. Chinese drill bit drills SQUARE holes
    By Brian McMillan in forum Off Topic Discussion
    Last Post: 10-11-2011, 03:51 PM
  4. Got to drill some square holes
    By Don Baer in forum General Woodworking Q&A
    Last Post: 08-03-2009, 03:38 AM
  5. When is a square edge not square?..............UPDATE!!!
    By Mark Rios in forum Neander Tool Questions and Show & Tell
    Last Post: 01-06-2007, 12:39 PM
